Question about Ergomotion TL100 Low Profile Twin XL Long Adjustable Bed
No power to remote control. changed batteries. nothing
My harbor breeze ceiling wont turn on.
  • Disconnect power at the source, not at the fan
  • Remove battery from remote. Press all buttons, then reinstall battery
  • Restore power. Using ONLY the remote, test operation
  • If the fan still does not work, disconnect power again and try every known combination of remote buttons and switch settings until the fan works or you give up in frustration.
Mar 13, 2017 | Dryers
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Dec 27, 2014 | Magnavox Televison & Video
Bought a new RCA 37LA30RQ. Remote worked for the first 2 days we had it. Now, when I press power (or an other button), the power button on the remote quickly flashes and nothing turns on. Changed the...
Im pretty sure all you need to do at this point is reprogram the remote. If you dont have the codes go to the RCA website. They normally loose the codes when the batteries die and you have to change them out and re-program it. hope this helps!
Sep 09, 2011 | RCA Universal Remote Control
I have a ViewSonic RC00136P remote control. It
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Mar 29, 2010 | ViewSonic Televison & Video
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
I have a remote RCR3273 and can't get it to control my Panasonic
I press the tv button on rca remote and it wont stay on, tryed holding tv button and entering code but power button flashes twice and turns off. Entered last number and nothing happed, cant find any other help.
Apr 27, 2009 | RCA Universal Remote 3 Device Remote...
Changed out batteries,still nothing
Firstly measure current on the battery using a avo meter,
check the contact of the battery tray
open a remote and clean contact buttons with contact cleaner,
close it and power,
Apr 09, 2009 | Televison & Video
My rca control is not working I already change the batteries but nothing happens.Can you help me?
I held down the "VCR" button in the top row and while holding it down I entered the code. Then I released all buttons and pushed power and LOW AND BEHOLD it worked.
RCA- RCR450c universal remote and a Orion VCR
Dec 09, 2007 | RCA RCR450 Remote Control
Ergomotion TL100 Low Profile Twin XL Long Adjustable Bed Logo
79 people viewed this question
Top Ergomotion Furniture Experts
Butch Fatherly
Butch Fatherly
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Joe Ball
Joe Ball
Are you an Ergomotion Furniture Expert? Answer questions, earn points and help others
