Question about Home
I need a new cartridge for Artema bath mixer tap
2 Suggested Answers
  • 659 Answers
SOURCE: I am looking for a replacement cartridge for a
Try The Faucet Parts store out of Arlington, TX. They specialize in faucet replacement parts. Their number is 817-649-8919. I bet they would be more than happy to ship you what you need.
Posted on Mar 19, 2009
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
I have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
PLUMBING>FITTING FLEXI TAP CONNECTORS TO BATH
NO PROBLEM USING FLEXIBLE HOSES. JUST ENSURE THEY ARE NOT KINKED WHEN INSTALLING
Oct 13, 2009 | Home
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
I am looking for a replacement cartridge for a Roca Pasific bath mixer tap
Mar 04, 2009 | Roca Pacific Semi-Recessed Basin - Black
Need to fit ideal standard lever cartridge to mixer tap
hi you 1st need to isolate both hot & cold water supplies to bath.lift the lever up & underneath the lever you will see s screw unscrew it & be careful not let it go down the plug hole, so a good idea at this point is to put in the plug!!!
Once the screw is loosened you will be able to remove the lever.
then there is a cover which will need to be undone & removed seeing as its gold you will have to be careful undoing this as it may be stiff, sometimes a few taps with the endle of a srewdriver handle will loosen it enough so you can remove it. once this is removed you will gain access to the hexagonal part of the cartridge, so yo uwill need to have the appropriate spanner or adjustable spanner. you will need to hold against the tap when undoing it so as the whole tap body doesnt move.once the cartridge is removed the new unit can be fitted in reverse order.it sounds simple but being Gold you have to be careful you dont damage it whilst attempting to remove the old one. Tip put some silicone gtrease around the o rings on the new unit as it will make it easier to remove if you ever have to remove it again?
Kindly
Richie
Dec 15, 2008 | Plumbing
Had new mixer taps fitted on sink and bath (water pressure was fine hot and cold before) but now have very low pressure on hot water. can anyone please help, as its taking 35 mins to run a bath.??????
can you check some other source of hot water? if the pressure there is ok?..if it is, then the problem is on the new tap that you fitted.
Jun 27, 2008 | Heating & Cooling
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
