Question about Kenmore Dryers
Sqeeky noise 86572810 squeel and squeaks
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
Dryer is making squeeling noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 25, 2011 | Dryers
Dryer making a horrible squeeling noise model DLE5955W
heatman101
Aug 31, 2011 | Dryers
Dryer makes loud squeeling noises when running.
heatman101
Asker
Jan 02, 2011 | Dryers
Loud squeeling noise. Sounds like a bearing.
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
Basically the dryer emits a squeeling sound. almost as a worn bearing would make. kinda starts out higher pitched and gradually gets to be a consistent squeel..
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 15, 2010 | Maytag Neptune MDE4000 Electric Dryer
Brake squeak when applying on my ford focus c max
They squeek or squeel because they may need adjustment or replacement. The noise is a safety feature when in need of replacement. Good Luck.
Sep 10, 2009 | 2007 Ford Focus (3 Door) Hatchback
Car makes a squeeling / skweaking noise
It is either your serpentine or another belt such as an alternator belt causing the squeak.
This can be resolved by either replacing the belt or making sure the tension is correct.
If it is a serpentine then replacing it will be necescary if it is alternator belt there are ways to tighten it.
Belt dressing is another temp fix for the squeal. the belts become glazed over time and will squeak and chatter spray some belt dressing on it and the squeak will go away for a while.
How loud is the squeak? 1-10
Jan 07, 2009 | 2005 Infiniti G35
Sqeeling
heatman101
sdfgjsdf
Aug 20, 2008 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
12 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
