Question about Dishwashers
Over level water error on samsung dht400rhs - Dishwashers
3 Suggested Answers
SOURCE: over-level water error
I finally found the cause of my "over-level water error", and I fixed it. In my case it was a gummed-up water level float chamber (part #13 in the diagram here). Once I pulled it out, cleaned it, and put it all back together the dishwasher is running fine. What follows are the symptoms I experienced, and some pictures of what I saw and did to fix it.
Symptoms: After nearly 2 years of owning a DMT400RHS, dishes began to progressively come out with sediment on them. They were not being cleaned nearly as well as previously. This symptom seemed to start fairly suddenly and remain for about 2 months. Then, the dishwasher began to occasionally error out, first with "Drain Error" or "Over-level water error", then later consistently with the "Over-level water error":
For awhile we could just restart the dishwasher and it would do a load. Later, however, no matter how many times we restarted, unplugged, etc. it would not continue. Of note, there was never actually a drain problem, as it would always, well, drain.
The error was never triggered during the initial "drain phase". It was always triggered after that phase, when it was filling the tub with water, specifically after it had been filling for awhile. Eventually, we figured there must be a float someplace that was all gummed up and not moving up with the water level.
Well, here's what I found when I finally pulled the entire dishwasher out and laid it down on its side (facing the door, tip it over to your right):
Inside that little box with all the sediment and glop is a wing-shaped float that couldn't move due to the glop. I simply held the whole plastic thing under the sink faucet to rinse it out. I had to take off the tub pan in order to pull off the drain hose that's attached to the back of this chamber. After rinsing it out, I put it back in and the dishwasher seems to be running fine:
Posted on Apr 21, 2013
hamzajoyce
I have the same problem with a brand dishwasher. I fixed problem by checking drain hole and machine worked no prob. The drain hole which connects to dishwasher drain pipe was clogged with gooy stuff from previous dishwasher. I cleaned drain hole and machine worked no prob ^^ hope this help .
Posted on Dec 29, 2013
Have samsung sw5ousp 5kg it is showing 4e water error any help b great thanx in advance
The Error indicates that the water level did not increase or fill in time to the machines estimation . 4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
Apr 18, 2016 | Samsung Washing Machines
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    Have over lever water error on samsung dishwasher
    Your: Have over lever water error Probably means over level? In other words water is too high I would guess. Sounds like you have a bad water level sensor, or connections from or to and from or to the "brain" I'd unplug to reset the "brain". but it that doesn't help it's probably service tec time. Ask to estimate the price.
    Mar 04, 2015 | Samsung DMT400RHS Builtin Dishwasher
    Low water level
    I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
    I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
    The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
    Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
    Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
    Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
    Error code oE
    According to page 25 of the users guide you can download from Samsung's web site at http://www.samsung.com/us/support/owners/product/DMR57LFS oE means, "Water level error (over-level)"
    Jan 20, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
    High Water Level ErrorSamsung DMT300
    The parts mentioned, 8058475/SWITCH, PRESSURE and 8058500/HOSE are Asko parts. Samsung should have their own equivalent parts, but the Asko parts should work as well... I think the Samsung parts would be less expensive?
    May 13, 2012 | Samsung Dishwashers
    What is E no 1 on washing machine wa13G7Q1
    Hi
    Error code 1E means WATER PRESSURE SWITCH ERROR. This error occurs when the Generated Frequency Signal of water level is low or high.
    WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz
    High Level = 15.00 Khz
    If the Water level is detected as low or high for more than 5 seconds, then it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 minutes after which you would get this error. To resolve this issue you can try and clean the filter screens inside the water lines. To check this disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back. This will resolve the issue.
    Daniel
    Sep 01, 2010 | Samsung Washing Machines
    Error code ( IE ) on my samsung washing machine model wa13g7q1
    1E - WATER PRESSURE SWITCH ERROR
    * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
    Samsung washing machine sw7oz1fw-yl start with errorr code E1
    This is Water Pressure Switch Error.
    A paragraph from the Guide :-
    Let me know, if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Dec 19, 2009 | Samsung Washing Machines
    Dishwashers Logo
    70 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
