Question about Hobart Food Mixers
Hobart c 100 speed control shifter loose
C 100 speed control shifter shaft is loose and willl not change speeds. Was running when I shifted speeds.
  • 68 Answers
SOURCE: Hobart Legacy HL120
I haven't ever worked on these units. But from looking at the parts catalog, (pg 4) and considering your failure, I would suspect you have a bad speed control. And being that it is a potentiometer, it's pretty likely to be the cause. (Item #1)
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/0420EE614011415A85256FE2004E0FFA/$File/F43101%20Rev%20A_lk.pdf
I would ask Hobart, but I doubt any special tools would be required. (NO splicing, crimping, or soldering)
I hope this helps - Mike
Posted on May 12, 2008
  • 49 Answers
SOURCE: Hobart C-100 mixer HELP!!!!
This is common there is a key on the shifter shaft and when you removed it the key came out and is floating in the grease in the tranny ready to destory the gears. That are no longer available at Hobart. if you want the shifter /switch plate off, remove the pin in shifter and the handle thats all. Hobart has a special puller I have two of them but you can use a H type puller to get to the pull threaded holes Mixer should be upside down on head to repair trans.
Posted on Sep 30, 2008
  • 13 Answers
SOURCE: Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Posted on Nov 15, 2008
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Posted on Jan 20, 2009
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Posted on Mar 17, 2009
Older, (1950) Hobart A-200 runs in first gear no matter where the shifter is set?
My Hobart had a switch on the side to change Gears... 3 Different Speeds
Apr 11, 2013 | Hobart Food Mixers
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
I have a hobart a-200 mixer. I rebuilt the transmission and got it up and running but the shifter when put into 1st gear still runs at 2nd gear speed. When I put the mixer under a load it slows down like...
Provided you have assembled the machine correctly you have probably tightened the planetary nuts too tight. Loosen both planetary nuts. Should be an acorn nut and a thin nut. Push the planetary all the way up on the shaft and run the thin nut up until it is snug. Back the thin nut off about 1/4 turn. Hold the thin nut and tighten the acorn nut against the thin nut. The planetary must have a small amount of up and down play in it or it will cause the problem you describe.
May 20, 2010 | Hobart A200 Stand Mixer
MY Hobart Hl200 is working with only 2 speeds when it used to work with 4 speeds.
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
Mar 16, 2010 | Hobart HL200C Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
I have a Hobart A-200 that shifts gears by itself, and sometimes doesn't shift properly with shift lever. Speeds are not always the same as shift lever indicates.
first tighten the top main shaft nut all the way, then back off 1/4 turn ,then go to the planetary nut remove acorn nut, the 1/8 wide nut tighten all the way then back off 1/4 turn reassemble mixer try oper. of speeds. let me know how you make out please
Oct 23, 2009 | Hobart Food Mixers
Jun 03, 2008 | Hobart N50 Stand Mixer
Apr 02, 2008 | Hobart A200 Stand Mixer
Planetary shaft for h600 is bent
Thats the center shaft and if it moves back and forth the lower bearing is bad or the shaft has cracked.You need to remove all 3 shaft assemblys. if you already removed the gears on the center shaft then you need to remove the shifting yoke---turn power off to machine then take the screws off the trim plate where you shift speeds,you might see a switch that sits up on the shifter cam,remove the screws and put switch aside,take the 4 allen screws off and pull on the shifter(it will come out).If you didnt already drain the oil do it before you mess with the shifter.after the shifter is out grab the upper left gear assy. and the gear assy. below it,rock both gear assy. and pull up,they will both come out(you might need some force)once out remove the remaining gears on the center shaft and remove the shifting yokes.you then need to remove the planetary (lower part of mixer)if not already done,then pull the shaft out from the bottom.any questions let me know.
Nov 19, 2007 | Hobart D300 Stand Mixer
Hard time moving from # 2 to # 3 speeds back and forth
At the risk of asking the obvious, are you aware that one must shut off this machine before going from one speed to the next?
Oct 22, 2006 | Hobart N50 Stand Mixer
Food Mixers Logo
27 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
