Question about Vacuums
Removing bottom cover from electrolux discovery vacuum
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
  • 70 Answers
SOURCE: Electrolux 1572E (Discovery II) How to remove
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Posted on Aug 10, 2009
  • 294 Answers
SOURCE: remove bottom of cover on vacuum bottom. Making a
on this model, the bottom does not come off but the top does. on the top hood there are 2 latches to turn with a screwdriver and the hood will come off.
Posted on Oct 18, 2009
SOURCE: how to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Posted on Dec 06, 2009
  • 694 Answers
SOURCE: looking for top part of vacuum of 1572E electrolux
You can order these, and other parts, at an Aerus Electrolux store. If the store is too far away, call and ask them to order one and ship it to you.
http://www.aerushome.com/storelocator/
Posted on Jan 31, 2011
How to install a new cord on Electrolux discovery model 1572E
un screw cover note wiring then reverse action taken
Feb 13, 2015 | Electrolux Vacuums
What does the question mark mean
The question mark means there is no bag in the vacuum.If there is a bag in place, check to see if the bag is covering the bag switch located to the bottom right with the bag door open. Remove the bag that is in it and find the switch. Replace the bag and make sure the cardboard on the bag covers the switch and close the door. The vacuum should run.
If it doesn't run you should take it to a vacuum repair shop that works on Electrolux vacuums.
Jun 29, 2014 | Electrolux Epic 6500 Vacuum
How do I get to the belt on my electtrolux discovery 2 vacum cleaner. took the bottom screws out but still cant get top off?
There are clips holding it together. On the bottom of the power head are two square "holes". Insert a standard screwdriver to release the latches. Once they've released and the cover is loose, turn the power head over and lift the back. Don't force it off.
You will then need to remove the screw at each end of the brush.
When reassembling it, be sure the front of the cover is inserted into the groove in the base. Then press gently down until it clicks into place.
Apr 30, 2011 | Electrolux Vacuums
How do i get into the electrolux discovery II powerbrush assembly? I have removed all screws but still no access?
There are two square holes on the outer side of the wheels. Use a flathead screwdriver in these to release the latches. Turn the powerhead over and carefully lift the back of the cover off and pull back slightly to lift off. To remove the brush and/or replace the belt, remove the tiny screw on each end of the brush and lift brush out.
Mar 20, 2011 | Electrolux Vacuums
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
How to remove brush cover of discovery advantage upright vscume cleaner
Lay vacuum on table or other surface on it's front.
Remove the 4-5 screws on the base plate.
There may be a rectangular hole on each side of the wheels. If so, insert a standard screwdriver and rotate gently to release latches.
Carefully hold the halves together and turn vacuum onto it's back.
Lifting from the back, remove the power nozzle cover.
If replacing the belt or brush, remove the screws located at each end of the brush. Lift brush out and remove belt.
You can no replace the belt, brush, or both. I also recommend giving the insides a good cleaning before reassembling. Make sure when you reassemble, insert the lip of the cover into the slot, then close the back. Some gentle manipulating may be necessary.
Mar 04, 2011 | Electrolux Vacuums
How do you get into Elecrolux Discovery Upright to replace bely
make sure you got all the screws, and then gently pry the cover off, its probably never been off i presume , have some patienc and you'll get it
there may be a fifth screw
Jan 16, 2010 | Electrolux Vacuums
How replace lightbulb on carpet beater (Electrolux central vac). Can't find any screws near light
To replace the bulb you will have to remove the power nozzle cover. Remove the cover by extracting the screws from the bottom. Take notice of which screw comes from which hole. Depending on the year, one screw may be shorter than the others. If put back in the wrong place, the screw will come through the cover when replaced. Once the cover is removed it's easy to replace the bulb. Make sure everything is lined up when reassembling.
Dec 30, 2009 | Electrolux Centralux Vacuum
Electrolux 1572E (Discovery II) How to remove suction motor cover?
Aug 10, 2009 | Electrolux Vacuums
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
