Question about Panasonic VIERA Televison & Video
Picture settings for a zt60
Plasma tc60zt60
Viore 42" plasma has picture but no sound
check first at the sound set up menu might set to off. if the settings is ok and the speaker is also good, the cause is either bad amplifier circuit or sound processor at the main board. at this time you will need a trouble shooting.
Oct 07, 2012 | Toymax Viore 42 in. Plasma TV
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
I turn on my 50PF9956 get sound but no picture. For 2 weeks before it started taking longer to get the picture. I tried the menu with nothing
The plasma picture tube technology lasts only 24 months before it burns itself out, requiring a new
plasma picture tube. The LCD and LED technologies do not suffer from this short life span.
If your Philips 50PF9956 is over 2 years old, you've got all the use your plasma can give.
Fix: new plasma display - the electronics controlling the plasma display are most likely fine - just
like the electronics providing audio to the speakers. Your set's only problem is a burnt-out display.
Jan 17, 2011 | Philips 50PF9956 50 in. HD-Ready Plasma...
Thomson AW3717651 TV has sound but no picture
It could be one out of the two problems..
1. The plasma panel or the components which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
Also the y-sus video board which is a common problem with plasma sets.
Call a competent person to remove the back panel-remove the board and power the set up-if it is this board the set will display the top half of the picture only-when replaced no picture will be displayed.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Thomson Televison & Video
My Phillip plasma tv is only giving out sound,and showing the menu and volume but no picture.
Nov 01, 2010 | Philips 42PF9630A 42 in. Plasma Television
LG Plasma has sound but no picture
Hi James,
This could be one of two problems. I can't narrow it down any further without having the set in front of me.
1. The plasma panel or the componets which supply electricity to the plasma in the panel have packed up.
As for the cost of repair, if it's the panel, buy a new TV. It'll be cheaper. If it's the component that supplies the electricity to the plasma on the panel or the video processing unit, expect to pay between 300-400 as a conservative estimate for parts. Labour would be another 100-200.
Hope this helps
Apr 28, 2009 | LG 42PX5D 42 in. Plasma HDTV
Grundig plasma
There is probably a fault in the video processor, or there is a setting for the user colour temperature that is not properly set. Call the authorized service for advice on how to proceed.
Jerry G.
May 13, 2008 | Televison & Video
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Plasma TV
Try to reset the TV to factory defaults and see if that helps. Record your color settings and any other setting your have in your config before dong this because all will be lost.
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
