Question about Archos PMA 400 (30 GB) Digital Media Player
Archos pma400 system files - Archos PMA 400 (30 GB) Digital Media Player
I can't download pdf files from emails on archos 101 8 gb tablet
make sure you have some PDF reader installed !! if it's already in your system then file format must be wrong or corrupted.
try for another files if problem presists then reply
Jan 23, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Every time that i click on my favorite icon,my archos 7 re boot it self,shut down then start back up.will not let me get into my favorite's files. any solution.
Hi, when this happens it usually means the operating system is corrupt, the best thing to do is to reflash your Archos, you obtain the required software and then plug into the USB port and then using the proprietary software to reflash the internal memory on the Archos to replace the operating system, and restore it to functionality, if you ONLY copy over the system files you will keep all you old settings.
You need to go to the Archos website to obtain the Firmware also there is s "How to" reflash your Archos 7.
http://forums.techarena.in/operating-systems/1150953.htm
Above is a "How To" link...
www.archos.com/support/support_tech/firmware.html?...g... -
Support link above.
Mar 02, 2011 | Archos 7 Internet Media Tablet
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
C) Computer
D) On the Archos 5 or 7
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Apr 15, 2009 | Archos Internet Media Tablet MP3 Player
Archos 400 won't turn on (error code 3)
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Mar 11, 2009 | Archos 404 Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
C) Computer
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Archos pma 400 usb device does not recognise
Device drivers are not loaded or not loadwed properly.uninstall them and go to the web site and download new drivers.they should then recognize the player.RICHARDM69
Dec 17, 2008 | Archos PMA 400 (30 GB) Digital Media...
Archos PMA 400 (30 GB) Digital Media Player Logo
18 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
