Question about Maytag PGR5710 Performa Gas Kitchen Range
Where is the reset button on a maytag performa oven pgr5705bdt
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: My Maytag Performa Gas Oven
Unless you are getting an "E" or "F" code on the display to suggest a part failure,the failed part is the control board.
Posted on Mar 30, 2011
Gas smell is strong on Maytag Performa when using the oven.........some times?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 23, 2011 | Maytag PER5710 Performa Electric Kitchen...
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Looking for heating element breaker or reset on a performa dryer
you have to take off the back its to the bottom left
Aug 31, 2009 | Maytag Dryers
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Set wrong load setting
you may have overheated the motor,try leaving for an hour or so and try on spin to see if it starts.hope this helps.
Mar 14, 2008 | Maytag Performa PAV2200
How Do I Use Self Clean Oven Feature?
Kathy - we just figured ours out!! Hit the clean buttton, will light up With "cl n", hit 2nd time and it will start the cleaning. Ours set for 4 hrs! Good luck!! This is for the maytag performance!
May 28, 2007 | Maytag PER5705 Performa Electric Kitchen...
Maytag PGR5710 Performa Gas Kitchen Range Logo
35 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
