Question about Vtech Lands Phones
Can we change the frequency channel on our phone the neighbors conversation is coming in on ours.
We have a vtech cordless with 2 phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Posted on Jul 27, 2014
SOURCE: vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
Posted on Dec 20, 2008
  • 5 Answers
SOURCE: Vtech 2656 cordless phone battery not charging
These phones seem to have this problem, I'm not sure a new battery will fix it. I have found a wierd fix that works for me, but I have no clue why.
1-take the battery out,
2-leave it out about 30 seconds,
3-then put it back in but leave the cover off,
4-place it back in the cradle however you can with the battery hanging out (I wrap it around),
Now it will charge much more thoroughly for some reason???
Posted on Apr 16, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
SOURCE: 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets: my vtech cordless phone says connecting and i can'...
my vt phone is lock and need to unlock it help
Posted on May 19, 2010
  • 8 Answers
SOURCE: We have 2 Vtech cordless phones -a 6.0 and a 5.8 I
Yes, that is normal for all cordless phones. they are really just a radio that sends a signal from the base/charger to the cordless hand set. when the power goes off the base does not work at all. Go buy yourself a cheap corded phone, and when power goes off plug it into any wall phone jack and then you can make calls.
Posted on Apr 04, 2011
Our phone rings, but we get the dial-tone when we answer and hear our neighbors conversation in the background
Change the channel or code setting. It's also possible the 'pairs" for your house and your neighbors are "crossed". Does it happen with all phones or just the cordless one. If it's all phones, the problem is in the phone lines.
Nov 06, 2013 | Uniden DECT 6.0 Cordless Telephone...
How do i change the frequency on a Vtech t 2340?
While on a call, press the CHAN button near the lower left corner of the T2340 keypad to change channels. See page 9 of this manual for details.
Jan 13, 2013 | Vtech VT-T2340 Phone
My vtech phone base keeps flashing line in use but there is no handset in use
See if you can open and check the line for conversation . or someone has a baby moniotr on the same frequency as your phone!
Sep 06, 2012 | Vtech 2-LINE 2.4GHz CORDLESS PHONE
HI I have a problem with tech CS5121 5.8 GHz when someone calls me i pick up the phone i hear a noisy voice while im talking with the person at the same time he doesn't hear that voice, so it actually...
Most likely this is just "bleed" over interferance from another cordless phone on the same frequency and/or channel. For starters I recommend changing whichever you can in respect to these to see if this fixes the issue. You might have to change them a few times to find a good setting without the issue.
This could be a case of lines being crossed anywhere from the wiring at your phone all the way to the phone company. If you live in an apartment environment it is possible for it to be crossed with a neighbors line. Although less likely, it could even be crossed wires from different houses. This could also involve the phone companies wiring anywhere down to their main connections.
Hope this helps...
Mar 13, 2011 | Vtech CS5121 Cordless Phone
I have a belkin router, cordless phone interferce
cordless phones and wireless routers transmit on the same frequency. Move the router away from the cordless phone if it's near, if not try changing the channel on your belkin router
Now if your WIRELESS connection drops, when the phone rings it's usually because of this:
You have a cordless phone in your house that is using the same channel as your wireless router. Now routers are generally quite different so there's no one way to fix this. Just look up your make and model of modem on Google and find out how to change the channel on your modem. It's pretty straight forward and not very time consuming to fix.
Also one thing to note is that you shouldn't automatically jump to the highest channel that you can because your wireless card may not be able to go that high.
Apr 18, 2010 | Belkin (F5D7230-4) Router (587009)
I hear neighbors conversation when I use mycordless v-tech phone. why do i hear them talking? I have had the telephone company out to check the lines and they are ok.
These are called interferences. Each phone base is an antenna. You and your neighbors probably have cordless phones that use the same frequency. Check with them ann con sider buying a different phone (different working frequency).
Remember that interferences are a two-way street. If you can unintentionally eavesdrop on them, so can they eavesdrop on you (unintentionally or otherwise.) You may also consider having a spare corded phone.
Jan 04, 2010 | Vtech VT-9161 Cordless Phone
Can a neighbor who has a similar digital cordless phone listen
It is possible. You gotcha try it out by carrying your cordless to neighbors hose and see if u can connect from there. If so get panasonic to change the frequency of your cordless........................sodeep
May 13, 2009 | Panasonic KX-TG1100 Cordless Phone
Uniden 3315 Frequency Problem
Your phone has Digital Enhanced Cordless Telecommunications (DECT), known as Digital European Cordless Telephone[1] until 1995, The digital filters will prevent interference from the bandwidths used by phones and wi-fi.
Your phone also incorporates dynamic channel allocation which switches frequencies when noise(static) is encountered.
Eventually your conversations take a wire route down the road. You are getting some "cross talk", an actual scientific term used to describe signal transmission from one line parallel to another by magnetic eddy currents. I would call the phone company and have them trace the problem.
May 13, 2009 | Uniden Lands Phones
5808 drops call and starts searching for base
Got a wireless router? Change channels on the router off Ch6, the default channel and that may help your phone communication to the base station. I have had wireless phone customers lose their wifi when their phone rings, same frequency or intereference on that frequency.
Feb 13, 2008 | Vtech 5808 Cordless Expansion Handset
Lands Phones Logo
91 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
