Question about Eureka Vacuums
Eureka 5838 Not working
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
What filters do I use for this? does the Hf-9 work?
Hey, this is Jeremy with Crucial Vacuum,
Unfortunately, you did not include what kinda of vacuum you were trying to make sure the Eureka HF-9 filter was compatible with. Below I have compiled a list of all of the models that the HF-9 filter will work with for you.
  • Fits Eureka Upright Style HF9 Victory & Whirlwind Vacuums.
  • Eureka Victory - 4300, 4400 & 4600
  • Eureka Victory Enviro Vac - 4370, 4377, & 4470
  • Eureka Self Propelled - 5184, 5185, 5187, 5188, 5190, 5191, & 5196
  • Eureka Whirlwind - 4180, 4380, 4381, 4480, 4481, 4483, 4488, 4489, 4580, 4686, & 4689
  • Eureka The Boss - 4672
  • Eureka Smart Vac - 4469, 4473, & 4476 & Sanitaire- S4170, SC4570, & SC4580 models.
You can purchase replacement parts for Eureka (including the HF-9 filter) direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 12, 2015 | Vacuums
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Where is the reset button on my eureka canister vac
with out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Jan 14, 2013 | Eureka Vacuums
Type of belt for it?
Your Eureka Whirlwind model 4489 uses the Eureka Style U belt. There are several different U belts that Eureka makes, including a generic one that's made by Eureka under the Smart Choice name. Eureka also makes a Eureka Style U belt Extended Life, apparently increase the life of your Belt.
Here are links to all of the Eureka U belts that will fit your model:
Generic Eureka U Belt made by Eureka for Smart Choice Brand
Standard Eureka U Belt Part 54312
Extended Life Eureka U Belt Part 61120
If you have any questions, or need help installing this belt, please just reply using the comment section on the repair page here on Fixya, and I'll be more then happy to answer any follow up questions that you may have.
If you found this helpful, please be so kind and rate the repair, or leave feedback for me, this is greatly appreciated by the Fixya community.
Thanks,
Chris Jones
GoVacuum.com
May 17, 2010 | Eureka Whirlwind 4489 Upright Vacuum
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
What type of belt fits best with my eureka altima 12 amp
The replacement from Eureka will work for certain, but any brand of belt that indicates it can be used on that vacuum will work.
Let me know if you have any additional questions.
Feb 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
No water and brushes not working
Sadly, the advice I got from Eureka was "Time for a new attachment". They can tell where to find a service agent. Call the service agent, and ask if Eureka has solved this problem. Don't waste your time trying to fix it - believe me, it's not worth it unless you are a master with switches, etc.
If Eureka has come up with a new design for that upholstery attachment, the service guy will know because millions are having problems with it (by the looks of it!). I also heard this model was discontinued, but I did not hear that from Eureka when I phoned about my problem.
Jan 14, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Vacuums Logo
10 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
