Question about Magic Chef CAV4000AWW Top Load Washer
Loud noise and not moving
Noise
Ge washing machine glwn5050mows loud spin noise
Replace the "tub damping straps" on the unit. Here are the parts to order and the is a video on that same page to show you how to access it. I think there are 4 straps on that unit.
Nov 20, 2013 | GE Washing Machines
Loud whinning noise
sound like transmission oil pump noise if you hear noise when vechicle accelerating moving.
Jul 29, 2013 | 2003 Mercury Mountaineer
Noise in operation. A loud rumbling noise when
Any noise must be identified with a good observation of the point of noise source.
This can be done with a good view with all safety precaution while the unit moves. Use good lighting and make sure that you are not putting your hands into any moving parts while the set works.
Now disconnect after observation and manually turn the drum, the motor and the rotor to fix the point of noise. this can be a faulty bearing assembly or a faulty suspension all of which will require a resetting/reassembly.
Feb 17, 2011 | Whirlpool LER4634J Electric Dryer
Loud AC unit outside trane high efficiency xb1000
The noise could be the fan trying to pull air through the condensor. Service cleaning should improve cooling and lower noise level.
May 21, 2009 | Heating & Cooling
Front wheels are locked loud noise
dear friend-it sounds like the drivetrain packed up,it is possibly the diff that broke and jammed the drivetrain.
Apr 23, 2009 | 1998 Dodge Grand Caravan
Cartride jam with loud noise
Hello sir; un-plug machine, now you move cartridge much easilier, just move for and back ,to find out what's block the way.
Apr 12, 2009 | HP Officejet 7130 All-In-One InkJet...
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Magic Chef CAV4000AWW Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
