Question about Toro Snow Blowers. Power Clear 621 QZR 21 in. Single-Stage Quick Chute Gas Snow Blower
Toro power clear will not stay running brand new
    Master:
  • 755 Answers
Is the choke closed when you start this thing make sure you close the choke to start then shut it off , the plug gets fouled if you do not do it this way make shore you have the right gas mix in it , takes 50 to 1 I believe 2+2
Posted on Jan 20, 2015
New 621E toro snowblower running on prime fuel has been running now will not stay on with choke out what do i need to do
HOW OLD IS THE GAS . PLEASE DRAIN THE GAS OUT OF BLOWER AND PUT FRESH GAS IN IT I WOULD ASLO GET WITH THE STORE THAT YOU BOUGHT IT FROM TO EXCANGE THE BLOWER
Feb 21, 2015 | Toro Snow Blowers. Power Clear 621E 21 in....
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jim
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn Mower Won't Run
ya didn't give much info but it sounds like the carb had plenty of time to varnish up. take the carb off and clean it make sure you take the fuel bowl off and clean the floate and floate needle good. an auto parts store will have what you need to do everything with
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Snow Blowers. Power Clear 621 QZR 21 in. Single-Stage Quick Chute Gas Snow Blower Logo
199 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
