Question about Konica Minolta bizhub C351 All-In-One Laser Printer
For a scanning problem
When I try to scan and store the file in my computer by konica minolta C351 , It shows message trying to gather information so can you tell me what should be the problem?
  • 167 Answers
What method are you using to scan? SMB, FTP, TWAIN, or scan to HDD and retrieve from computer. Trying to gather informations sounds like it is trying to access something like an LDAP or remote settings/server.
Posted on Jan 08, 2008
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
Can someone please walk me through how to set up a minolta c351 scan to email. I am using gmail for the pop3 settings but for some reason i keep getting the serever connect error message. I have used the...
your pop3 settings should not need a number after them...you should contact your email provider for the settings....or if you use outlook, you can go to tools, account settings, and see the settings for your email there...
Aug 09, 2009 | Konica Minolta bizhub C351 All-In-One...
Cannot scan items to an ipaddress
There could be a number of things causing this, including port blocking at your server level - check with your IT professional.
It would help to know how you're trying to scan (i.e. scan to e-mail, scan to FTP, scan to desktop), if the C351 has an EFI (Fiery) print server incorporated and how it's set up for scan interfacing with the copier. There's so many variables, it would be very difficult to pinpoint any one solution without knowing just how the copier and your network are set up.
Aug 07, 2009 | Konica Minolta bizhub C351 All-In-One...
Adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
May 01, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
How to set scan for a new person on bizhub c351
After pressing "scan," press "Direct Input," then "Scan to E-mail." That will come up with a digital keyboard with which you can enter the e-mail. You'll have to type out the whole address, as on my printer (even though I have the manual) I can't seem to find out how to save it so you don't have to type it in every time...
However, after inputting the e-mail address, press "Start" and it should scan to the e-mail.
Nov 19, 2008 | Konica Minolta bizhub C351 All-In-One...
Weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
Oct 14, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub 252 scanning problem
It sounds like you have too many things stored on the Copier.
100% just states the status of available memory.
Do you have jobs stored on the device?
If not, try reducing the rsolution of the item you are scanning.
Those models do not have much memory to begin with.
The socket error is just it's way of tellingyou the file was not sent.
Jun 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
289 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
