Question about Goodman Heating & Cooling
Gas regulator How to clean a regulator
    Novelist:
  • 189 Answers
Just replace it
Posted on Nov 28, 2014
WHERE IS THE FUEL PRESSURE REGULATOR ON 1994 CHEVY PICKUP
SKM, fuel pressure regulator is on top of throttle body. This could be the problem, could also be vacuum leak, faulty EGR, etc. You may want a good Tech, to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TBI 220 Fuel pressure regulator change 1
92 chevy truck missing at constant speeds The 1947 Present Chevrolet GMC...
Where is the fuel pressure regulator on 1994 Chevy truck 5 7 TBI fuel...
started stalling and dying when in gear
Jul 28, 2016 | Cars & Trucks
Fridge air gas dryer
You need to replace it. Once a regulator stops working, you can fix it.
May 05, 2013 | Dryers
Pilot stays lit, burner comes on but only a portion of the burner area has flames.
remove burn tray clean out all burners sounds like all sooted up then check gas pressure to see if adequate gas pressure
Sep 13, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
There is no gas going to the rotisserie
Hi cmzimonja...
Check to make sure you have gas in your tank/tanks.
Check the gas regulator, remove the hose from the grill and turn on the gas, you should hear,smell gas coming out of the regulator hose, if you do not then replace the regulator as it is defective.
Sometimes you can tap on the gas regulator with a hammer and it will free the needle inside and get it to working again.
Check to see that the outlets for the gas is clear and clean.
Please take time to rate me
Sep 18, 2011 | Dacor OBC52 Gas Grill
Low flame on a 2600 dometic fridge/ flame is not enuff to keep fridge cold
Hi and welcome to FixYa, I am Kelly.
Download this manual:
http://www.dometic.com/9efb3e8b-c980-4383-952c-996a35e3c872.fodoc Go to page 12 for burner cleaning. Clean the burner and the gas orifice (jet) thoroughly. If after cleaning you still have the problem you may have to remove the solenoid vavle and clean out the gas safety valve. The manual also mentions checking LP gas pressure. A weak LP regulator will cause a low flame. I would clean it first... and if you still have a low flame check / replace the LP regulator before tearing into the gas safety valve.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Dometic RM2620 Refrigerator
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Nexgrill 720-0073 stainless grill. The grill doesn't get very hot - around 200-250 and the flame level is low (BOTH sides). Tried a new tank of propane - same thing. I cleaned the burners late...
Hi and welcome to FixYa. I am Kelly.
Things that cause low flames
1. LPG Tank regulator internally corroded and diaphram can not open enough to supply the correct amount of pressure. (replacement regulator required) If you do an tapping on the regulator disconnect it from the tank and if you do strike it... use WOOD! Tap from bottom and then from top.... several times. When your done... do it one more time. This may correct the problem for a short period but if it is corroded internally the problem will repeat in as little as a month.
2. The orifice holes are restricted due to spider webs insects ets. (Remove burner and Physically clean the orifice mounted on the back of the gas valve.) Worst case the orifice has to be removed and the mini orifice hole cleaned.
3. Clogged internal burner air / gas passage (remove again and clean) Use a tooth pick to clean main burner holes. Use spot tie or something long and skinny to probe into the burner air / gas passage. (Wire coat hanger works too)
4. The burner gas valves on the stem nut side are coated with grease not allowing full movement of the valve stem inside the gas valve. (remove and clean with engine degreaser)
Thanks for choosing FixYa.
Kelly
Sep 07, 2010 | Nexgrill 720-0234 (LP)
Jpg328 does not light up after changing gas bottles? There is no gas coming from out the four cooktop burners. In front of the pressure regulator there seems to be gas pressure. the spark ignitors works...
After in detail troubleshouting and cleaning all gas passage of the cooktop and checking if no pessages are blocked,I myself went looking to the pressure regulator just after the gas bottles. After making some adjustment to this pressure regulator, the cooktop light up again. So problem is solved.
Jul 26, 2009 | GE 30 in. JGP328 Gas Cooktop
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
