Question about Ricoh Aficio 2035 Copier
The photocopy ricoh 2035 give me parer was misfed , procedure for clearing misfed paper is shown inside front door but there is no any paper how can i solve this probleme?
2 Suggested Answers
  • 62 Answers
SOURCE: The printer is saying that paper was misfed and it
First you have to open all the doors see their are two papers are get jamed in side, one paper at C section that meens in fuser module and another one in lower papaer tray section you can find the nob of C when you open the front door please rotate that the C jamed papaer comes out and other one open lower right door op tray-2 and tray-3&4, you can see the Ajamed paper remove that and close all the doors if problem exists call expert-thankyou
Posted on Dec 19, 2010
Ricoh Aficio 3228c misfed paper j001. paper jam
This means the machine has been turned on with a jam inside the machine someplace. If you have opened everything in the machine and found nothing then it is time to call a service technician.
Aug 03, 2017 | Ricoh Office Equipment & Supplies
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Richo 2045 paper misfed in C. I HAVE CHANGE THE PHOTOSENCOR AND THE PROBLEM STILL EXIST
i think you were cleaning the machine so when cleaning these type of machines you must be very careful.Okay you must change laser unit and don't blow these machines when cleaning because once the dust goes to laser unit it gives you a code/paper misfed so try to change laser unit
Sep 14, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
The printer is saying that paper was misfed and it says that procedure for clearing misfed paper is shown inside the front door : C and A
Dec 15, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
Keep getting misfed paper message. can't see paper
Check the paper tray. The part at the end of the paper might not be keeping the paper pushed to the front of the tray. Remove the tray and check the rollers that feeds the paper. They might be slick. Clean them with some WD-40 sprayed on a rag.
Nov 22, 2009 | Ricoh CL4000DN Laser Printer
Ok WHile I waited for the reset directions I took the fuser and roller assemblies off the 2035 I had and put them on this 2045. Still had the error. So I put them back on the 2035. Put the originals back...
Hello sir; I don't know what's the problem of the machine, anyway I can give you reset procedure; Press "clear/mode" "107" and press and hold "clear/stop" key for 3 sec.until screen change, then turn off the power and back on again.
Nov 13, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 2035 Copier Logo
16 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
