Question about Compaq Presario Desktop with AMD Sempron Processor (CQ5300y
Does compaq presario cq5300y motherboard need replacing
Monitor says no signal keyboard won't work in USB port fan is on mouse works in USB port
sandrew
  • 2961 Answers
SOURCE: compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Posted on Jan 15, 2007
melnavz
  • 1226 Answers
SOURCE: COMPAQ PRESARIO SR1010V!!!
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
Posted on Feb 04, 2008
  • 100 Answers
SOURCE: Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Posted on Jun 27, 2008
  • 139 Answers
SOURCE: Compaq EVO D500 Keyboard/Mouse Issues
Just read this carefully as you will get a problem to your solution.
My Computer ->right click ->properties ->hardware -> device manager -> in last you will find USB controllers -> unistall all the usb controllers one by one. Restart the machine and your USB devices will be working fine
Enjoy
Posted on Jan 13, 2009
jell587
  • 447 Answers
SOURCE: Motherboard crashed in My HP Compaq Presario S6500NX
According to these specs it should be an Asus A7V8X-LA. This link will show you a list of these boards available on ebay.
Posted on Feb 23, 2009
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Replaced motherboard, no signal on monitor
IF THE COMMUNICATION PORT FOR YOUR DEVICE IS NOT UNBOARD THAT IS IF THE KEYBOARD, MOUSE AND YOUR VGA CARD ARE THE REPLACEABLE ONE, TRY TO CHANGE THOSE CARDS THEY MIGHT NOT OK ANY MORE. IF YOU STILL HAVE SAME PROBLEM THEN THE MAINBOARD IS NOT OK, ALSO, YOU CAN CHECK YOU MEMMORY CARD THAT IS RAM IF YOU DON'T ATTACH IT PROPERLY IS CAN CAUSE THE PC NOT TO BOOT. IF IS RAM FAULT YOU WILL BE HEARING SOUND FROM YOUR BOARD, ATTACH IT PROPERLY.
Nov 19, 2008 | Compaq (203966-001) Motherboard
Desktop PC...Compaq Presario SR1010V Dont work
Appears to be a bad motherboard. Replace it.
Feb 04, 2008 | Computers & Internet
Unresponsive usb ports
same thing going on with mine...sounds like hardware aka motherboard
Nov 25, 2007 | Compaq Presario Notebook
Dead mouse port
Had u checked it with new mouse..
If showing same problem.. u need to replace the motherboard..
Nov 19, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario Desktop with AMD Sempron Processor (CQ5300y Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
