Question about GE JVM1653 Microwave Oven
Technical specifications - GE JVM1653 Microwave Oven
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Ewave manual ew13f1b
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Your model of microwave oven has a rated output power of 1100 Watts. See page 5 of the user's manual for complete details and specifications.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.mcappliance.com/document/EW13F1B.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 26, 2011 | Microwave Ovens
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
F-2 keypad shorted
Ok, the ratings are figured on how long it will take the microwave oven to cook a specific meal(meat potato)etc.. They use that type of data to figure the ratings based on actual wattage and size and time in time out ratio. The actual technical ratings are not figured at all. its all based on cooking time verses meal size. Concerning this repair, this is a normal repair quote and, the actual charge is quite common with this type of repair. The actual part price is right on the mark and, the labor is usually 46 dollars and hour with a 2 hour minimum. I would defiantly cut my losses and purchase a new unit. I'm sure a new unit can be purchased at a lower price than the actual repair fee.
Jun 05, 2009 | KitchenAid KHMS155L Microwave Oven
Sharp R308np microwave
To my knowledge your chances of finding any technical info on this unit are slim to none. I would replace it. New ovens are very reasonable and have great features.
Ray
Nov 23, 2008 | Microwave Ovens
Product: daewoo combi-microwave model KOC-8H4YSL purchased: 31/12/06 problem: Err2 warning given when trying to defrost items. User manual instructs to switch appliance off and call technical support. No...
Chances are you have a bad temperature sensor (thermistor).
You can contact Daewoo here: http://www.e-daewoo.com/customer_service.asp
Or find their nearest service center here:
http://www.e-daewoo.com/service_center_location.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 14, 2008 | Microwave Ovens
How high should my micro wave oven be mounted from the floor?
There is no specific height, your can mount accordinf to your convenience to operate.
Apr 07, 2008 | Microwave Ovens
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
GE JVM1653 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
