Question about Motorola Mobility Wimax wireless broadband Modem CPEi35775
Can i use motorola wimax modemCPEi35775 as second modem
How do i format wimax modem bm328
Typically, you "format" a hard disk. Your modem doesn't have a hard disk.
Most likely, you want to "return to factory setting". Turn it off first. there should be a reset button on the back, it may be hidden or even be just a hole you poke a paper clip wire in.
Hold the reset button down and turn power on. Keep holding the reset button 10 seconds. That should reset it to original.
May 25, 2015 | Computers & Internet
I can't get my Belkin G Wireless router to work with my Clear WiMax modem even after keying in the security key..is this router compatible with this modem?
Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
Apr 04, 2012 | Belkin Computers & Internet
My wimax cpe modem was originally 192.168.254.1 when i reset it it became 192.168.1.1 and i cannot access the internet anymore. How can I fix it?
my wifi wimax cpe huawei has 5 bar signals but still no internet. Why and how to solve this problem pls. Manay tnx!
Jan 13, 2011 | Computers & Internet
I have a Tata Wimax broadband, i have got a D-Link DIR 600 Router, i have tried so many times to go through both easy setup CD and Manual setups but invain.. i am frustrated!!!! I am able to connect to...
Ok...don't panic....take it all back out thru control panel>add/remove...reset your wimax modem by the little reset hole in the back as this can be an issue sometimes by adding the modem in the incorrect order. You should install everything but the "lan" cord from modem to modem last. A good test is to take the "lan" cord from your winmax modem and plug it right into your pc and you should have internet.
Jan 03, 2011 | D-Link DIR-600 Router
What is the default password of motorola wimax CPEo 35450
Default user name and password of your modem is :
User Name : admin
Password : admin
Regards
Ashly
Feb 26, 2010 | Arris SURFboard SB4100 Modem
Motorola Mobility Wimax wireless broadband Modem CPEi35775 Logo
50 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Motorola Mobility
Motorola Mobility
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
