Question about Troy Bilt 5.5hp Self Propelled Mower
Troy-bilt snow thrower 5521 will not start - Troy Bilt 5.5hp Self Propelled Mower
SOURCE: Electric starter won't engage with the engine.
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
freetek
  • 5568 Answers
SOURCE: Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Posted on Aug 14, 2009
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
  • 35 Answers
SOURCE: my troy bilt snow blower
I am guessing you did not run a gas stabilizer through the unit. Start the unit and run it while spraying carburetor cleaner in spurts into the carburetor. What has happened is that the small amount of gas has dried or what we call varnished causing internal parts to stick. If that fails, removed carb and disassemble and clean, reinstall.
Posted on Dec 13, 2010
How do I replace Blower Bearing?
Strip down, remove shaft, push out seals and then bearings. Take bearing and seals to a bearing supplier and they will replace by the part number on the bearing. Refit will plenty of lubricant.
Mar 04, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
How do you adjust steering on a storm 3090 xp ?
howdie the Pins in the front adjust the holes According to your Height or lower them Thks For your Time
Sep 04, 2014 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Hi
Disassembly the starter and ceck the starter housing,the armature,the end cover(with brushes and springs) and pinion gear.Also check the wires.Charge the baterry.
best regards savumihai71
Dec 21, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
