Question about Kenmore Vacuums
Replacing the base on my kenmore canister and can't get the rear wheels off the old unit.
3 Suggested Answers
SOURCE: I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Posted on Jul 30, 2010
ercupa190
  • 12223 Answers
SOURCE: sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Posted on Jul 11, 2012
Sears canister vacuum rear wheel won't stay on
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Wheel is sticking. I want to remove the wheel to clean the axel. kenmore 116.27514700
Thanks for the clarification. This is actually fairly simple to remove the rear wheel, however as you'll see after this has been removed, there really is no axle attached to this. It just snaps into the main canister housing. It may be that your wheel has broken, and a new wheel may fix your problem.
First here's a link to the parts shematic for your model so you can follow along:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11627514700&productCategoryId=0642000&brandId=0582&brandDescription=KENMORE&modelName=VACUUM-CLEANER&diagramPageId=00001&componentDescription=CANISTER&documentId=P0706048&blt=06
Simply put a flat head screw driver behind the brush, and pry it off. It will easily come right off. You may inspect the wheel, and the wheel housing that it snaps into to make sure there are no obstructions, or pet hair that are slowing the wheel down. Also look at the clips that hold the wheel in place to make sure there's no debris above the clips on the wheel that could slow down the brushes also.
If it all appears to be fine, you may spray some WD40 on the part of the wheel that spins, reinsert it back in the vacuum cleaner and test to see if that fixes it. If it didn't, you might just want to purchase a new wheel assembly.
Here's a link to the rear wheel for Kenmore canisters if you'd like to purchase a new one from our website:
http://www.govacuum.com/kenmore-panasonic-canister-rear-wheel-assembly-panasonic-part-ac99caktzv07-sears-part-4370702.html
Hopefully that helps you. If you have any questions about how to repair this, or other questions that I did not address, simply just add a comment as you did last time, and I'll be more then happy to answer any and all of your follow up questions.
If you found this repair helpful, please be so kind and rate my repair, or leave feedback. This is really appreciated, and one of the reasons that Fixya repair professionals continue to post free repair advice on Fixya.
Chris Jones
GoVacuum.com
Apr 27, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Belt broke, can't get bottom off
if it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Oct 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore canister hose
The part number for the hose is 4370993, you can go to sears.com, put int he part number and order it. You will only get just the hose, you have to take the ends off of the old one and put them on the new hose.
Mar 11, 2008 | Kenmore 22822 Canister Vacuum
How to open case??
I don't know this vacuum personally, but i'll take a stab at is. You're off to a good start prying around. There is most likely a coupld of screws holding things together somewhere. Check around the bottom and sides for holes where phillips screws may be lurking.
Hope this helps. Please rate this accordingly.
Feb 03, 2008 | Kenmore 22313 Bagged Canister Vacuum
Wheels (rear) How do I remove them?
you might be better off taking it to sears. taking the rear wheels off may do more damage then before.
Dec 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
13 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
