Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
Bissell 86t3 leaking - Bissell 1672 BIGgreen Wet/Dry Vacuum
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
What are common leaking problems with the bissell bg10
If you are having a leaking problem check your clean and dirty water tanks and the caps. Determine what is leaking. It could be a loose cap which we have here.
If the tank itself is cracked you will need to replace that part. You can find parts for the BG10, BG10N2 and 86T3 here.
GoodVac.com
www.goodvac.com
1-800-775-6586
Jul 08, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 86t3 leaking from flow indicator
You may have a broken gasket, either the dirty tank gasket here or the motor gasket here . Check that everything is tight and nothing is cracked.
GoodVac.com
www.goodvac.com
1-800-775-6856
Feb 08, 2014 | Bissell 1672 BIGgreen Wet/Dry Vacuum
My Bissell vac & shine leaks
Hey, sorry to hear you're Vac&Shine is leaking. Here's a quick link to assist you with your machine.
http://www.bissell.com/FAQDetail.aspx?id=1231&cid=ccsocial
Dec 22, 2012 | Bissell 60P4 Vac & Shine Cordless Stick...
The tools hose on a bissel powerbrush carpet cleaner leaks
Sorry to hear you are having issues with your BISSELL deep cleaner. Your upholstery hose should not leak when used. There is a small o-ring on the end of the hose that may be missing, or if the tool is cracked it could leak. A service center could better help you identify the problem. Here is a link to find your nearest BISSELL Authorized Service Center: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Sep 25, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1720-1 Little Green
If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
Feb 29, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
54 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
