Jvc interiart television - RM C1811H
Hi, we are having problems adjusting the tv screen to fit the TV programme when my father in law is watching football. The scores that appear at the top left hand of the screen we cannot see it. I have tried to adjust the screen by the remote and manually on the tv but cannot get this to fit. Other than having a smaller picture nothing seems to work. Do you have any suggestions please ... we are desperate to get this sorted out for him. He has a JVC 50inch tv. Many thanks !
ice man
  • 68 Answers
SOURCE: JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Posted on Mar 28, 2007
leorcid
  • 281 Answers
SOURCE: Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Posted on Feb 09, 2008
SOURCE: How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Posted on Jan 12, 2010
gopakumarg43
  • 73698 Answers
SOURCE: i have a 32" tv jvc iart and horizontal white
Hello
You are seeing vertical retrace lines. This faut is due to the vertical output section inside your TV. To rectify this fault, you must open your Tv. Just open it after unpluging it from the wall power socket. Locate the vertical output section on the printed circuit board.
It is easy to locate. You can see four wires goes from the deflection yoke; the coil fitted around the neck of the picture tube. Out of which two of them will be thick, usually red and blue coloured, and the other two will be thin. These two thin wires are for vertcal scanning. Just follow these two thin wires, and you will reach a point where these four wires are pluged onto the main circuit board, very near to the LOT. Upside down the printed circuit board, and follow the print of that two thin wires, and you will reach to the vertical output section of your Tv.
Before doing anything, just look for any loose soldering or bad solderings there. It is very difficult to find out loose solderings, as thay will be microscopic, I advice you to resolder most of the soldering points there by applying a little more solder; without making any solder short. Resolder all the pins of the vertical output IC, and see the effect.
If this does not help, replace the two or three electrolytic capacitors, at about 1000MF to 2200MFD there, with same capacity and voltage ratings. Make sure about their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Note the polarity when resoldering them out of the board. This must solve ypur problem.
If you need anymore asistance, feel free to contact me through Fixya. OK
Wish you sucess.
Posted on Dec 11, 2010
  • 3 Answers
SOURCE: I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Posted on Sep 24, 2012
hook up box to a stereo thur av jacks if it dod it thur stereo then its not your tv its your sky
Sep 19, 2013 | Televison & Video
I have a jvc interiart tv and when i turn it on the picture breaks up as if i have no signal however my signal is fine and if i turn it on and off lots of times eventually it starts working and the picture...
A few thoughts and a suggestion first.
If using the coax fitting for the signal try connection of any DVD etc to a rear input to see if same problem. This will tell you if the problem is related to the TV's tuner.
If using a cable/sat box/ receiver unplug each and wait a while and plug back which will allow each to try to reboot.
If no issue with the DVD etc via rear inputs you could bypass the whole issue by routing your signal not to the cable fitting but to one of the sets of inputs on rear of set
Let me know what you find and if you have questions.
May 28, 2012 | JVC Televison & Video
Where do I complain about background noise and music on TV. I have no hearing problems at all, but the unnecessary background (music) noise is dreadful it gives me a headache and it is louder than the...
You will need to adjust the audio on your TV. In this case I would shut down the bass boost and shut down the surround sound. Surround sound is sometimes called expansion sound. These are located on the menu under audio control. You may be satisfied with operating the TV in mono sound. Try this and see if this is better.
Feb 13, 2011 | JVC AV-32260 32" TV
Where is transformer located in jvc interiart tv model no av-28x4sr when i turn on tv the power light comes on but the screan stays blank and a clicking noise comes from back of tv the tv is about four...
good day your tv has no transformer.the subtitute of transformer is avr or automatic voltage regulator. maybe your tv has a defect,either flyback transformer or the main board. has a shorted parts.
Jun 21, 2010 | Televison & Video
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
TV picture size (height) adjustment
TV model # PCJ 612 R SAMSONG SERIAL # 39Z 300 125 W
Dec 06, 2008 | Televison & Video
JVC Interiart 32" Digital TV. No longer turns on. Has a thin horizontal line across screen when TV is on. No picture.
The thin line indicates that there is no vertical. This is usually controlled by a single IC (vertical IC). Look for a small flat IC attached to a heat sink with 9-14 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC with a new one.
Keep us posted.
Dan
May 09, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
