Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
Bissell 86t3 leaking from flow indicator - Bissell 1672 BIGgreen Wet/Dry Vacuum
  • Bissell Expert
  • 324 Answers
You may have a broken gasket, either the dirty tank gasket here or the motor gasket here . Check that everything is tight and nothing is cracked.
GoodVac.com
www.goodvac.com
1-800-775-6856
Posted on Oct 16, 2014
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
How do I fix sucton on my bissell prOheat2x ?
Check the filters. There's one on the water tank cap (looks like a screen) and one under the Flow Indicator: turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and the filter is under it. Clean and reinstall in reverse order. If that doesn't work contact the Bissell Consumer Care at 1-800-237-7691 Hope one of those helps.
Feb 17, 2015 | Bissell Vacuums
My bissell portable stain remover shampooer leaks water from the bottom
Check your Customer Care Guide for the location of the filters. I'm not familiar with this machine but if it has a "Flow Indicator" there's a filter under it. Just screw off the Flow Indicator Cap and you'll find a rotor. Under it is a filter that gets clogged and needs to be cleaned. There's usually a filter on the cap of the water tank as well. It looks like a screen, remove it and clean it too. The back pressure can lead to leaking. If that didn't help call the Bissell Consumer Care at
1-800-237-7691 Hope that Helped.
Feb 15, 2015 | Bissell Vacuums
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
How do i fix my carpet cleaner from leaking from water tank
First Check and Clean filters: Unscrew the Flow Indicator cap to remove it. Lift out the rotor and the filter. Clean the filter and reinstall in reverse manner. Hope that helped, if not contact Bissell Consumer Care at 1-800-237-7691
Dec 24, 2014 | Bissell ReadyClean Deep Cleaner
What are common leaking problems with the bissell bg10
If you are having a leaking problem check your clean and dirty water tanks and the caps. Determine what is leaking. It could be a loose cap which we have here.
If the tank itself is cracked you will need to replace that part. You can find parts for the BG10, BG10N2 and 86T3 here.
GoodVac.com
www.goodvac.com
1-800-775-6586
Jul 08, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat flow indicator wont spin
Hey Traci! You may want to have one of BISSELL's Authorized Service Centers inspect your machine.
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 11, 2013 | Bissell Vacuums
How to clain filter on bissell 1697
The clear cap on the flow indicator unscrews and the spinner and filter can be removed to clean.
Jul 11, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
496 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
