Question about Bissell Big Green Complete All-In-One Vacuum and Deep Cleaner - Green
Why is flow indicator leaking? - Bissell Big Green Complete All-In-One Vacuum and Deep Cleaner - Green
    Habit-Forming:
  • Bissell Expert
  • 159 Answers
Contact Consumer Care 1-800-237-7691
Posted on Jan 30, 2016
8910-4 bissell proheat pet doesnt want to suck up water
First thing is to check the filters. There's a lint filter on the heater tank cap. Just remove it, clean it and put it back. Then there's a filter under the Flow Indicator: turn the flow indicator counter-clockwise and remove it. Lift the rotor and filter out. Clean the rotor and reinstall them. Screw the Flow Indicator cap back on. If that doesn't work, then you may have something stuck in draw up tube. At that point I'd call the Bissell Consumer Care people at 1-800-237-7691 Hope that Helped.
Oct 24, 2015 | Bissell Vacuums
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
My bissell portable stain remover shampooer leaks water from the bottom
Check your Customer Care Guide for the location of the filters. I'm not familiar with this machine but if it has a "Flow Indicator" there's a filter under it. Just screw off the Flow Indicator Cap and you'll find a rotor. Under it is a filter that gets clogged and needs to be cleaned. There's usually a filter on the cap of the water tank as well. It looks like a screen, remove it and clean it too. The back pressure can lead to leaking. If that didn't help call the Bissell Consumer Care at
Feb 15, 2015 | Bissell Vacuums
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
How do i fix my carpet cleaner from leaking from water tank
First Check and Clean filters: Unscrew the Flow Indicator cap to remove it. Lift out the rotor and the filter. Clean the filter and reinstall in reverse manner. Hope that helped, if not contact Bissell Consumer Care at 1-800-237-7691
Dec 24, 2014 | Bissell ReadyClean Deep Cleaner
Bissell 86t3 leaking from flow indicator
You may have a broken gasket, either the dirty tank gasket here or the motor gasket here . Check that everything is tight and nothing is cracked.
GoodVac.com
www.goodvac.com
1-800-775-6856
Feb 08, 2014 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Why is water coming out of flow indicator?
any thing that is put together can leak , and will eventually
Nov 08, 2013 | Bissell Big Green Complete All-In-One...
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
No Spray from Bissell 7920 ProHeat Pro-Tech s/n 01222111
When you put the cover back on, was the piston on the bottom of the smart mix knob? If it was, did you have the smart mix knob in the water only setting? Sometimes the flow indicator cap may be on too tight, loosen it while it is running until fluid starts to leak out, then tighten it until it starts spinning. On the bottom of the tanks, are the seals on the tank and not sitting the the hole. You may have pinched a line when you put the top cover back on. May still have junk in the lines somewhere, try running a mix of vineager and water (not on the carpet), that mix may clean it out.
Sep 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Powerwash Proheat, flow indicator not rotating
Is it spraying? Is so, maybe the cap for the indictor can be too tight, or loose, maybe be bad and allowing an air leak. The white filter under the indictor may need to be cleaned. If no spray:
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and mater thru it to see if it will unclog it.
Apr 24, 2008 | Vacuums
Bissell Big Green Complete All-In-One Vacuum and Deep Cleaner - Green Logo
451 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
