Question about Uniden Cordless Phone
Uniden model number #1484-4 base doesn't work
My uniden base for model 1484-4 shows nothing on the lcd monitor.
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
cnavarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
SOURCE: Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
jyackle5
  • 8197 Answers
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Posted on Dec 31, 2009
Need manuel for uniden bearcat trunktracker iii police scanner
Check your scanner for a model number. I have found an online manual for the Uniden BCT15X from Uniden: http://info.uniden.com/twiki/bin/view/UnidenMan4/BCT15X . This model has the TrunkTracker III logo to the upper left of the LCD screen. The Uniden logo is to the lower left of the LCD screen. The model number is given above the upper right of the LCD screen. Then the Bearcat logo is below the right side of the LCD screen. Some other Uniden scanner manuals are available here: http://info.uniden.com/twiki/bin/view/UnidenMan4/UnidenScannersUsersGuides . Scroll down to the Individual Scanners section to find the links.
I hope these links help.
Dec 13, 2015 | Uniden Radio Communications
How to I get a security code for my uniden sect 6 D 1484 cordless phone that I bought at a garage sale?
The remote access (security) code is chosen via the handset:
press [menu]
scroll to "Ans. Setup" press [select]
scroll to "Security Code" press [select]
enter the two-digit code of your choice
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1484) to www.manualslib.com
and you can download a free copy of the manual.
Nov 11, 2015 | Uniden Lands Phones
I need a user manual for a UNIDEN DECT 6.0 cordless phone
Which model Uniden phone? There are a number of DECT 6.0 phones, Uniden has most of their manuals available on their support site: http://www.uniden.com/scat/cordlessphones_mnl . The DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The phones are listed in numerical and alphabetical order (so check the later pages if your phone's model number starts with DECT). Ignore the number after the dash in the model number, that indicates the number of handsets sold with a given base. The manual is the same for a specific base phone.
I hope this helps. If you add a comment with your model number, I will be glad to help you find your specific model.
Apr 01, 2012 | Candy CNW136 Front Load Washer/Dryer
I just received your Dect 6.0 from E.Bay....second-hand....I need to download the manual for it in order to use it properly.....Thanks...MC...!!!!
Which model of the Uniden DECT 6.0 phone do you have? They make several. All of the Uniden manuals are available from Uniden support and on the individual product page. If you start at http://www.uniden.com, you can search for your model.
DECT phone manuals are listed here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Then scroll through the list to your specific phone and desired language for the manual. The model number is on the base of Uniden multi-handset cordless phones. The number after the dash indicates the number of handsets that come with the base when purchased new but the manuals are identical.
To access all Uniden manuals, start at http://www.uniden.com/scat/cordlessphones_mnl and select the type of device.
If you add the model number in a comment and I'll be glad to provide a direct link to the manual that you need. For example the Uniden DECT1060 manual is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1060om.pdf .
I hope this helps.
Aug 01, 2011 | Uniden DECT 6.0 Cordless Phone
I have (3) Uniden telephones in the house. We went on holidays for (2) weeks and switched off (2) of them. We switched them all on when we returned but now only one unit fully functions. The other two will...
Sounds like you need to re-register the 2 handsets that are not working properly. Sometimes the handsets must first be de-registered then re-registered to the base unit. Send a comment with the model number of the base unit and handsets if they are not original handsets and I will give specific information for your phone. I have included a link where you can download the manual for your Uniden cordless phone by model number.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 28, 2011 | Uniden Lands Phones
I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
No called ID
Does the LCD just display "Incoming Call"? if so please list your model number and I might be able to help you further.
Jun 23, 2010 | Uniden DECT 6.0 Cordless Telephone...
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden Cordless Phone Logo
19 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
