Question about Panasonic Lumix DMC-FZ10 Digital Camera
Fz10 memory card error
Using SD Ultra Xc 1 card, I have memory card error, and cannot get past this message to format the card
  • 903 Answers
SOURCE: Format the SD Memory Card
Formatting erases all the data recorded on the SD Memory Card. If an SD Memory Card becomes unreadable, formatting may make it reusable.
Posted on Aug 31, 2005
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
pixeldawg
  • 71 Answers
SOURCE: Memory card error
If the card works on OTHER devices, and you've formatted the cards... the only conclusion you can really have is that it's a problem with the camera. Repair or replace.
Posted on Jul 08, 2009
SOURCE: Using a sdhc card in a Panasonic DMC-FZ10
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Sorry
Posted on Jul 16, 2009
  • 11967 Answers
SOURCE: I just bought a
Insert the card. Go into the camera menu and find "format" and follow the on-screen instructions.
Posted on May 03, 2011
Wont accept a new 64GB sd card
The XP10 works with SD cards, 2GB or smaller, and SDHC cards, 4GB to 32GB. It will not work with 64GB SDXC cards.
Apr 14, 2014 | Fuji Photo Film Co. Ltd FinePix XP10 12.2...
Memory card error
I suggest trying another SD Card to see if you get the same error message. If not then it was the card.
Oct 01, 2013 | Panasonic Lumix DMC-FZ10 Digital Camera
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Nov 10, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Sorry
Dec 18, 2008 | Panasonic Lumix DMC-FZ10 Digital Camera
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
SD Card
They have not had a good reputation for reliability here, you might want to do a search on SanDisk. The consenses on SD cards seems to be Panasonc, SimpleTech & Lexar (32x best), in that order. Some (Pixy) have had good luck with th Ultra II, but several others have had SanDisks of all kinds fail.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
29 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
