Question about Gevalia CM-500 12 Cup Coffee Maker
Doesn't brew Lights work, but unit does not heat up or brew
It will not brew coffee all lights go on but will not brew
The heating element has probably opened and needs to be replaced.
Sep 10, 2015 | Coffee Makers & Espresso Machines
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Machine will not dispense water at all,leaks behind dispenser, doesn't brew coffee
Hi. Great machine. You have a brew unit blockage. Remove the brew unit and clean. It canbe striped down and cleaned, but does requirer a bit of expertise in stripping them. Dazza REPAIRER
Sep 23, 2011 | Saeco Royal Digital Plus Coffee...
IT IS NOT WORKING .THE LIGHTS ON BUT IT DOES NOT BREW.
Its does not brew because there a defect in heater or thermostat. The heater inside the coffee maker is the one that responsible for heating the water and the thermostat is the controller of the heater. Either of these two should have defect, it will cause no brew because it has no heat.
I hope I give you idea for the problem of your unit.
Mar 27, 2011 | Keurig B70 Coffee Maker
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
Coffee not hot enough
hi elite 288! have you tried pre-heating your coffee cups? i fill w/hot water, then set them on cup warmer until i brew coffee (dump out water & slide cup under spout at last moment) and i do my frothing of milk before brewing espresso. also, have you allowed adequate time for machine to warm up/run just water through machine: after it indicates it's ready to go, hit the brew button & allow about a 1/2 cup or cup of water to run thru, warming up the brewhead. when ready button again lights up, brew your espresso. if this doesn't get it hot enough for you, try descaling your machine (you can look online or in manual for how to do this). since you have a refurb unit & heating element may not have been replaced, it could have some build up on it causing it to heat up all the water less efficiently. if this doesn't work, you may need to have the place you purchased it from diagnose and repair. good luck!
Jan 11, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
152 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
