Question about Dirt Devil Breeze Bagless VacuumVacuum
Auto adjust height work
Install wheel assembly
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
Very hard to push, the automatic height adjustment seems to be stuck in low postition
I'm growing tired of telling everyone what a piece of **** this vacuum is, I think you'll be the last! There is a design flaw that forces the wheels down according to how low you are holding the handle. Even when holding it at a normal operating height it is too low by design, causing difficult operation and finally multiple belt breaks! see my other posts about how to fix this, although it may not be worth your time!
Sep 22, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Height adjustment won't work
The height adjustment for the vacuum will only work when the handle is in the released position. The knob will turn easily when the handle is locked upright, and when released you should feel a fair amount of resistance.
Aug 30, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
Jul 11, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Kirby vacuum height adjuster is stuck in high
Remove the nozzle and remove the front wheel shaft. Take these 2 screws out.
When doing so - watch for the spring that is under the top pedal, do not let it fly out of window. If you will find that shaft is bent buy and install a new shaft (you can find all parts HERE). You may try to straighten it but usually it doe not last long - wheel ***** falls off and you have to buy new shaft anyway. If shaft seems to be ok - clean old grease and dirt, lubricate well the pedal teeth and assemble everything back. This should solve the problem. Occasionally spring may be broken but this happens very rarely.
Good Luck,
Rocky
Mar 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hight adjustor does not work...
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Dirt Devil Breeze Bagless VacuumVacuum Logo
24 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
