Question about Honda Black Max 2600 PSI Pressure Washer
Low water presure - Honda Black Max 2600 PSI Pressure Washer
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Mar 05, 2015 | Washing Machines
Low oil presure while driving
im sorry there is no pressure off.
running pressure is low because.
1: wrong oil, or AF in oil, or brake fluid from jiffyboobs. or water.
2: fuel in oil , bad bad bad.
3: dumping additives it it. bad.
4: BEARINGS IN ENGINE SHOT. (warn bad)
5: THE GAUGE FIB'S.
I NEVER NEVER NEVER trust car gauges, i use MINE>(in hand)
i also test my hand gauges, (ask)
Jul 08, 2014 | 1994 Isuzu Rodeo
Low presure
sometimes the water pressure from the house is insufficient, when it happened to me it would run weird. The water would come out in spurts because little water would come out of the water hose. You could try and lower the pressure on the machine to compensate for the lack of pressure going in, that's all I can think of.
Jan 21, 2012 | Karcher Garden
My AC wont blow cold. As soon as I put freon in it, it blows cold for about an hour, then hot again. My friend told me that the orifice tube in his car needed to be replaced because it was convertine the...
Sounds like you might have a leak. If you charge the system and works for a time ,(hour, week, year) and then quits it sounds like perhaps the freon is leaking out somewhere. Freon does not ever get converted to air. Freon is in several states of existance while it is in your system. It is a high presure liquid, high presure gas, low presure liquid, and a low presure gas, but it is still always freon.
The valve your friend is talking about is called an expansion valve. What it does is to take the high presure "liquid" freon and allows it to pass into a low presure zone called an evaporator at a regulated rate. When you take freon at a liquid state high presure condition and expose it to a low presure environment it "evaporates" ( thus the name evaporator) and it gets very cold when it does this. This is where the cold air you feel coming out of the vents is made.
But the freon is in an enclosed system. By this, I mean it is never exposed to air, moisure (water), or anything else. I goes through all of these changes while inside this enclosed system.
Therefore, if the enclosed system is good then the amount of freon inside it will not change. If the amount of freon doesn't change then adding more will only make things worse.
I would suggest having the system checked with a hologen leak detector and/or system dye to find the leaks. Remember, if you have to add freon, then the freon that was there before must have escaped from somewhere.
Find a reputable shop to check the system for leaks. If it is leaking bad enough to run low in a hour it should be an easy to find leak.
Apr 13, 2011 | Chevrolet Cobalt Cars & Trucks
Shower keeps coming up with low pressure and water goes
think ur presure redusing velve [prv] is durty and ur hot and cold water is not balenced presure . the prv is 90% of time located in 1m radius on cold water seply to geyser look for a curtrage , unscrew clean out and put back. will fix the problem
Plz rate my advice
Jun 01, 2010 | Home
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
710 d has problem in hydrolics ax like main pump is destroking to soon no power in all hydrolics. did presure test found low presure in charge circuit on test port on main pump .have checked or replaced...
hydraulic pump may be going out, you have to have a good working pump for your hydraulics to work right, there are also some check valves that could be leaking, this will also give you a low pressure reading, low pressure will also effect pto engagement
Oct 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Whirlpool dishwasher low water presure upper level
Since you have low pressure
  • Check the float switch inside the tub, it should move freely up and down.
  • Check the harness to the motor
  • Check start capacitor on the left side of the wash motor
Jan 31, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No water at outlet
plidded up inlet is what it sound like, or too low like you said
Jan 11, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Honda Black Max 2600 PSI Pressure Washer Logo
22 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
