Question about Vehicle Parts & Accessories
2001 Cadillac Deville Northstar Engine thermostat location
I need to replace the thermostat in my 2001 Cadillac Deville with Northstar engine. I am having cooling problems & my heater don't work
SOURCE: 1999 cadillac deville overheating
my husband did everything that everyone else did that had this overheating problem. It was so weird that my engine cooled at a light and heated up going down the road. I have a north star 4.6 engine and this is natorious for happening. my check engine light also came on and so I had a diagnostics done which told me my #1 injector wasn't firing , car ran like **** as well. After putting in a new water pump and plugs,ect. and realized injector was good a friend told him we could have a blown head gasket. So just to see if this was the problem I went to buy a bottle of glassbeads and the auto parts guy told us to purchase a bottle of BARS STOP LEAK BLOCK SEALER NOT RADIATOR BUT BLOCK SEALER $31.99 . He followed the directions and we waited 24 hrs. before driving it. What ever the problem was has stopped my car runs like brand new and I am loving it again. no over heating no injector problem, runs great.......I hope this helps. I know its probly a temperary fix but its a fix and now we know what the problem was. SASSY
Posted on Mar 19, 2009
  • 4 Answers
SOURCE: Problem with overheating on 1996 Cadillac Deville with Northstar
The oil life resets to zero after the engine overheats. Check for external leaks first, make sure the water pump belt is still there and turning. The most likely cause if the car has over 70,000 miles is head gaskets.
Posted on May 18, 2009
emissionwiz
  • 75822 Answers
SOURCE: how to replace the thermostat on 2001cadillac deville
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is 1n the the waterpump housing cover. Remove airbox and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermo housing. These systems are a lil finiky about air pockets....so fill slowly and let run at idle until operating temp and let cool and chk level.....fill as needed and repeat if needed.
Posted on Jul 06, 2009
  • 1608 Answers
SOURCE: where is the knock sensor located
The knock sensor is located under the intake manifold.The starter is also located under the intake manifold.Hope this helps.Good luck.
Posted on Jul 21, 2010
Testimonial: "it was helpful informations,appreciate that."
leethedeuce
  • 4472 Answers
SOURCE: When does the timing belt need to be changed on a
The northstar engine uses chain driven cams that eliminates the need to replace timing belts.
Thank you and enjoy,
Lee
Posted on Aug 09, 2010
Testimonial: "Thanks for the quick answer.One less thing to worry about!"
Where is the hi heat sensing control to turn on the fans to the radiator located on a 2000 cadillac northstar engine , mine is turning on at 222 degrees and i think thats to high , i would like to change...
REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP TO BE ON THE SAFE SIDE.I SEEN CADILLAC RUNS A 192 TO 199 DEGREE THERMOSTAT.CADILLAC 4.6L 4.9L ENGINES ARE BIGGER THEY RUN A LITTLE HOT THAN MOST ENGINES.
Sep 14, 2010 | 1999 Cadillac DeVille
Where is the thermostat located on a 96 Cadillac Northstar engine. a pic would help.
on driver side under the hood at front remove the bottom radiator hose from the engine remove two bolts and the thermostat is behind that make sure you install it correctly
Aug 29, 2010 | 1996 Cadillac DeVille
When does the timing belt need to be changed on a 2001 Cadillac Deville with a Northstar engine?
Lee
Aug 09, 2010 | 2001 Cadillac DeVille
I just need to a general idea of where the starter is im gonna change it out is it under the thermostat on the left side of the motor on the tranmsn. side right? i have a 2001 cadillac deville.
If you have the NorthStar engine then then the starter is under the
intake manifold, no I am not joking. You have to remove the plastic intake
plenum to replace the starter, its a pretty big job and I would not advise you to do it yourself unless you are trained.
May 23, 2010 | 2001 Cadillac DeVille
Where do i find the thermostat and how do i replace it on a 2001 cadillac deville
The thermostat in the northstar engine is located at the bottom radiator hose (unlike most conventional cooling systems), the hose connects into the housing where you will also find the water pump.
Remove the hose from the housing,then remove the two bolts on the flange,the thermostat can then be pulled out.
Take note of the orientation of the thermostat as you remove it.
Don't forget the new gasket, you may have to order this separately.
Mar 30, 2010 | 2001 Cadillac DeVille
Need to locate the thermostat for replacement. where is it?
The thermostat is located on the drivers side,In front of the belt driven water pump.If you havent had much experience with the northstar engine you may wanna have a repair shop replace it.
Jan 29, 2010 | 1998 Cadillac DeVille
Replacing the thermostat on a cadillac deville
Assuming you have the Northstar engine....
Don't forget the new gasket when you install your new stat.
Jan 12, 2010 | 1995 Cadillac DeVille
Diagram of cadilac northstar engine exploded view of a cadilac northstar engine
need 1998 northstar engine diagram to change the head gasket thanks
Sep 30, 2009 | 2001 Cadillac DeVille
How to replace the thermostat on 2001cadillac deville
Jul 06, 2009 | 2001 Cadillac DeVille
Replaced water pump. thermostat. radiator, filled with dex col, still overheating This is a 2001 Cadillac Northstar engine
Try backflushing,if this doesn't solve the problem,..then it could be the distributor,they can make the car run hot if the are going out.
Apr 08, 2009 | 2001 Cadillac DeVille
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
