Question about Samsung NE58F9710WS 5.8 Cu. Ft. Electric Range Stainless Steel
Set code te - Samsung NE58F9710WS 5.8 Cu. Ft. Electric Range Stainless Steel
Hi ! I'm using a Casio TE 2400 cash register, I'm trying to change my 6% tax back to 0% tax rate Due to my country new law . Tq so much for the help
The TE-2400 uses programming sequences from the manual if you want to set it yourself. You can turn each tax on or off in the departments or set the rates with codes. This site has the special dealer manual and they can show you how to use it if you have trouble with the codes https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Hope it helps
Jun 11, 2018 | Retail Supplies
I have a used Casio TE-M80How can I reset to factory settings, ie get rid of previous business heading on a post sale receipt
You need to use the multitap codes in the manual. The TE-M80 has a unique way of entering characters. There are a couple of pages of instructions and codes to do it. If you don't have a manual, these guys have it listed: https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-M80_users_and_programming_manual.html
Also, make sure you use the paper saving mode. This model eats printers if you print on every sale.
May 01, 2017 | Retail Supplies
Error code tE
if you replaced the thermister
and tE comes up
then its the heating element has failed
and or its thermal safety fuse set up perhaps failed also
Apr 28, 2015 | Washing Machines
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Im using TE2400 but i do know how to set table number into the mechine
Hi. You type the table number, then press the NEW/OLD button, or sometimes it may have a NEW CHECK button. The machine must be set up for table tracking before you can use these functions. Your dealer should have set the MAC code for table tracking files, then memory allocation for enough tables, then the keyboard buttons required for tracking.
If anyone needs a TE-2200 or TE-2400 Casio manual, try here
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Aug 25, 2010 | Casio Parts Cash Register PC Desktop
Casio TE 2200 0 instead of 0.00 I just bought the new te 2200 but i can not programing. is that the problem with mac code ?
Yes. This machine has not had a RAM clear and system settings performed. Take it back to the dealer and ask them to perform the dealer programming on it, then you can program the user data for products etc yourself. ------------------------------------------------------------------------------------------------- If anyone needs a Casio TE-2200 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_users_manual.html
Jun 03, 2010 | Casio Parts Cash Register PC Desktop
Te-2200 can't calculate tax-on-tax
Hi.
Have you set your departments or PLUs to use both taxes?
Dec 11, 2008 | Casio Parts Cash Register PC Desktop
Setting up pin codes for operators TE 4500 F
Here's a place to find the manual:
http://www.microtill.com/product_info.php?pName=casio-te4500-cash-register-3
Click on the picture of the manual where it says "download manual". The manual should explain it for you.
Nov 26, 2008 | Casio Parts Cash Register PC Desktop
Samsung NE58F9710WS 5.8 Cu. Ft. Electric Range Stainless Steel Logo
15 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
