Question about Whirlpool MH1170XS Microwave Oven
Shuts off after a few seconds
After pressing start, unit starts but quits after a few seconds.Never runs longer
When i use the microwave,it starts for 2 seconds then stops
Robert, I will post links below that may address your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Microwave Shuts Off After Few Seconds
http://forum.appliancepartspros.com/microwave-repair/2937-panasonic-starts-then-stops.html
Why does my microwave runs for few seconds and stops
Appliance Repair Forums
Feb 24, 2016 | Microwave Ovens
Unit cuts off
see this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jul 12, 2013 | Samsung SMH9187 Microwave Oven
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Microwave quit working
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be the high-voltage rectifier diode.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Feel free to post your brand and model so we might be able to give me specific info.
Nov 21, 2007 | Microwave Ovens
Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Oct 12, 2006 | Panasonic NN-T990SA Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
