Question about Bose & Wave& Music System
Clicking noise and skipping
When cd is inserting a clicking noise and cd skipping ocurs
Why won't my CD Player won't play CD's?
the laser that reads the cd is probably dirty - if you have a can of compressed air - insert the nozzle into the cd player and blast away any dust and debris - if this doesn't help - there are cd cleaning discs available at any major retailer - just insert the cd and it cleans the laser - worst case scenario - buy a new cd player - the prices have really come down - I replaced mine with the trim kit and wire harness for $100 - only took about 1 hour - but you do need to buy the Ford stereo removal tools (available also at any good stereo store)
Aug 22, 2014 | Audio Players & Recorders
Tsstcorp cddvdw sn 208ab
Probably the drive is failing. The internal clicking indicates the drive is trying to read the disc but can't.
Jan 09, 2014 | Computers & Internet
I think there is a part missing to this cordless keyboard . I am handicapped and just can't figure out. i bought 2nd hand
the keyboard should have,,
1.) the keyboard
2.) usb adapter
3.) driver cd
1.) insert the usb adapter to the computer
2.) install batteries on keyboard.
3.) INSERT DRIVER CD AND FOLLOW INSTRUCTIONS
4.) If noting pops up on installin the cd then skip step and continue
5.) button on keyboard press the connect button on the usb adapter.. (if there isnt one skip this step)
6.) when the driver installer comes up, click install drivers automatically
Thats it your done!!
6.) press connect
Mar 05, 2010 | Logitech Cordless Desktop Deluxe Optical...
Trying 2 burn cd and my computer is sayind cant
try reinstalling the burner then restart ur computer if the problem still ocurs then right click on my computer then manage then device manager then right click on ur system name (eg tom234) then scan for hardware changes and update ur drive, if the problem still ocurs then change the cable(sata or pata) then try.
Nov 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
Receiver will click off
check your power supply to make sure the correct amps and volts are there. check your speakers to verify the correct ohms for the receiver. if the ohms are to big you will shut down because it overdraws on the receiver.
Jul 28, 2009 | Audio Players & Recorders
Cd player not functioning properly. when cd is inserted there is a clicking noise and then a coed appeares (e 2).Help!!
the clicking noise is most likely the laser trying to focus on the disk, make sure the cd is clean and if thats not the case clean the cdrom player with a cd player cleaner
Sep 03, 2008 | 1995 Oldsmobile Aurora
My 02 Maxima's CD player freezes and skips.
my cd changer skips alot i dunno wht to do i cleaned it it woorks fine while sitting still but as soon as i drive it skips:(
Nov 21, 2007 | Car Audio & Video
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Bose & Wave& Music System Logo
26 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
