Question about Elna Sewing Machines
My elna lotus tsp machine keeps jamming and creating excess thread under the foot when I first start to sew like the tension is wrong but i can't see why
SOURCE: I have an old but still wonderful tsp lotus elna
try sewingpartsonline.com
Posted on Nov 15, 2010
SOURCE: I need a 240 volt power cord and foot pedal for an
try sewingpartsonline.com & look for the elna name & then look for your model number, it wasn't posted, so I couldn't look it up. but the have a lot of model of elna's...
if they don't carry your model check with sewvacdoctor.com & ask them about the part
also could check on ebay
Posted on Sep 07, 2011
  • 16 Answers
SOURCE: I have an Elna Lotus sewing machine. The needle
Most frequently the needle is just in backwards or threaded from wrong side, or using the wrong needle- check it over.... The presser foot must be released to press on fabric else the tension adjuster will be set to zero tension and could cause issue. Expect simple stuff else timing was knocked out of adjustment (from striking something, etc)
Take two adjustments and call me in the morning... for real, get back to me if it isnt anything basic I will try to describe timing procedure
Posted on Oct 21, 2011
SOURCE: I require a manual for elna airelectrinic tsp machine please.
check with elna website
sew4less.com
sewusa.com
a1sewingmachines.com
Posted on Apr 22, 2012
Tally Girl
  • 1129 Answers
SOURCE: I have an elna airelectronic tsp machine & cannot thread bobbin. Please help
Firstly, have you got an Elna metal bobbin? it should be solid on the bottom and have 7 holes on top. It is essential that you always use it this way, wind it with the holes on top and load it into the bobbin holder the same way.
Have a look at the image above, you need to load the bobbin in and click the thread into the tension spring so it doesn't lift back out when you pull the thread upwards. There should be an audible click as it goes in.
If you can't get it right or this image is just too small, feel free to email me and I'll send you the image and talk you through it, I have a TSP machine too. cwrogers@tpg.com.au.
Also, check my tip on bobbin winding here http://www.fixya.com/support/r10598580-winding_bobbin_correctly it is important to get a good even tension onto your bobbin as you wind the thread on, you may need to manually add some tension to the thread as it winds off the spool, as I've described in my tip. I sold these machines for Elna and customers would bring them in complaining of problems with their machine. Almost aways, it was the needle in backwards, bobbin upside down, thread/lint buildup in the bobbin race or badly wound bobbin that was the problem.
Hope this helps you Gaylene, but if not, please email, I may be able to send you the relevant manual pages.
Posted on Jun 15, 2012
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
I have the Elna 320. The top thread is getting caught in the bobbin and creating a snarl. What's wrong?
probably the top thread is not under tension correctly, or the thread has not been placed into the take up lever, its generally a miss threading or lack of tension on the top thread that leads to it being pulled down into the bobbin area. Recheck your threading from scratch, always thread up the top with the presser foot raised as this opens up the top tension discs so the thread can properly seat into the tension device.
May 29, 2014 | Elna Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
I have a circa 1962 Elna and the thread keeps tangling under the pressure foot by the bobbin. I have rethreaded it twice as per instructions in the owners manual and still is happening, any suggestions?
if you are getting loops on the underside of the fabric or jamming around the bobbin, then your top thread is not under tension or going through the thread take up lever, that little arm that moves up and down. Recheck your threading path making sure you always raise the presser foot to open up the tension discs so that the thread lies into the tension discs fully. Also check that you have the bobbin threaded up correctly into the bobbin case, with the thread caught into the tension spring (you will hear a little click as it goes in). The bobbin will turn anticlockwise as you draw thread out of it. Use the top thread to raise the bottom thread up, replace the needle plate and bobbin case cover in place, then take both threads to the back of the sewing area. Hold them firmly as you start sewing! very important that you don't allow the thread tails to be caught and dragged into the bobbin as they will jam around the rotary hook.
May 05, 2014 | Elna Sewing Machines
Have inherited my mom's elna Stella tsp air electronic. The foot control became harder to press, then stopped working. Elna want ZAR858 for a new part! Can I repair it?
Im confused, Stella TSP air electronic has a round black and white air foot with a black air line to the side of the machine like this.
or the earlier Lotus TSP has a electric foot and cable which is made of older style plastics, these are harder to find now but Sewingpartsonline.com carry an aftermarket one like this
No, not cheap parts but beautiful machines that with TLC work so well.
Mar 23, 2013 | Elna Sewing Machines
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
Oct 30, 2011 | Elna 2007 Mechanical Sewing Machine
I have an Elna Lotus sewing machine. The needle thread isn't being connected with the bobbin thread yet it was sewing just fine previously.
Oct 21, 2011 | Elna 2007 Mechanical Sewing Machine
How do I insert the bobbin into an Elna Lotus sewing machine (the old Lotus with flip sides)
Elna bobbins have holes on the top, so wind the bobbin with the holes on the top too. The Lotus bobbin winder doesn't have a tension device, thread just goes through an eyelet. So, place your scissors curved handle on top of your thread spool as it unwinds the thread to ensure the thread then winds onto your bobbin evenly. Also watch the bobbin fill and give the thread a nudge with your finger tip to fill top and bottom as well as the middle part, you want it to wind evenly across the full width of the bobbin. When full, pop bobbin winder back to left, cut thread and pull off the bobbin.
Then place the bobbin into the bobbin holder with the holes on top, and pull the loose thread tail around anti clockwise into the tension device and gently "click" it into the tension spring with the tip of your finger while holding the bobbin still with your other index finger.
You will be able to tell if it is in tension if you then pull the thread and it doesn't come out of the tension spring. It should feel firm with resistance but still release thread to a gentle pull. tally_girl_6.jpg Now thread the top down to the needle and holding the end of the needle thread, hand wind the fly wheel towards you to lower the needle and pull up the bobbin thread. Close the bobbin cover.
Always hold the two thread tails at the back of the sewing area as you start stitching a seam until you have stitched at least 4 or 5 stitches to avoid thread jams.
Lotus is a lovely vintage machine - there is a user group on Yahoo Elna heirlooms where you can find lots of info and pictures shared by members.
Dec 07, 2009 | Elna 8007
Sewing Machines Logo
26 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
