Question about Bosch Drills
Hammer doesn't work on model 11241evs
Drill works but hammer does not
  • Bosch Master
  • 1,824 Answers
A broken ring blocked the impact bolt in front that must beat the chisel. will not move in no direction. machine is dry or leak .or broken gear shaft ?
Posted on May 09, 2016
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
Chuck68
  • 42 Answers
SOURCE: Chuck broke on my hammer drill
To take a chuck off of your drill open it up all the way.
Inside there's a screw that you have to take out. It has to be turned clockwise to get it out.
You may need to struggle with it a bit because it's usually really on there tight.
Some folks even use a second drill to loosen it up and that's a really good idea if you have access to one.
Once you get the stubborn little screw out, put an Allen wrench in the spot where the bit would fit in.
If you can't turn it--and you probably won't be able to--then try using a rubber mallet to (gently) hit the arm of the Allen wrench to get it to turn.
Then you should be able to just take it out.
Put the new chuck into the drill.
Add a few twists of the Allen wrench in the opposite direction.
Tighten it up good.
Put the screw back in place and also tighten that up good.
The drill has a lot of vibration and if these aren't tight, it'll cause problems down the road.
Your drill, expertly fitted with your brand new chuck, should now be good to go.
Please rate this solution
Posted on Jan 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have the black and decker hammer drill model
look at the back of the brush holder for a tab that the forward/reverse lever locks into, it might be broken not allowing it to shift.
Posted on Mar 03, 2009
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
comax
  • 154 Answers
SOURCE: Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Posted on Apr 13, 2009
Bosch hammer not hammering 11241EVS
sometimes the hammer switch does not engage properly,try operating a time or two.
it is also possible its runner ring is broken inside,general this makes a funny noise when operated in this mode
Jul 05, 2017 | Bosch Drills
How to disassemble a Bosch 11241 hammer drill.
This is a pretty complex tool to tear down, make sure you're up for it.
1) you need to remove the bit holder assembly (#21-30) by prying the rubber seal off on the end, sliding the sleeve off, removing the hog ring, and then the 2 pawls along with the remainder of the bit holder parts.
2) In the nose of the tool behind the bit holder is a large snap ring (#154) that must be removed.
3) Remove the screws on the gearcase cover on the top (#873) and remove the cover.
4) The entire barrel assembly will slide out of the nose (This is generally not easy)
5) Using an o-ring pick or small screwdriver through the holes on the side of the barrel you can reach another hog ring on the inside - once released you can push the striker and hammer out from the nose out toward the piston end.
I would install a service kit and fresh oil if you decide to open this up Bosch 11241EVS 0611241739 Rotary Hammer Parts
Nov 11, 2016 | Bosch Drills
Where is the oil filler hole on the bosch 11241evs
There is no oil filler hole - you have to open the gearcase up (#873) to put oil in. If your hammer is leaking and losing oil you should put a service kit in it and fresh oil. Service Pack 1617000430 for Bosch Power Tool eReplacement Parts
As you can see this is an involved process and I would strongly recommend bringing it to a service center to have a qualified tech do this one.
Aug 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
I NEED TO KNOW THE NUMBER CARBON BRUSH USE IN MY 11241EVS HAMMER
Carbon Brush Set number 1617014135, They cost around $14.00 for the set.
Jan 27, 2011 | Bosch 11241EVS SDS-Max Rotary Hammer
HI,my Hitachi 18v DV18DL Hammer drill will only run in reverse,any help?TKS Rob
the triger contacts could be fouled. clean the contacts if it doesn"t work you can order a new trigger assembly from hitachi---ACE hardware may even carry this
Dec 30, 2010 | Hitachi Dv18dl 1/2 18v Hammer...
Bosch 11241EVS combo hammer, spins slowly.
have you tried turning the speed dial up and down a few times, sometimes that works. I am not aware of any to bypass the electronic circuits in this tool.
May 23, 2010 | Bosch Drills
Drills Logo
208 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
