Question about Miele Cat & Dog 326i Bagged Canister Vacuum
Clean power head for Miele 326i
I need a diagram to put the power head back together for a Miele 326
Bounced down a step while on, blew house circuit breaker, now s548 only powers on when on its side
Rickhan,
I would recommend taking it to a Miele dealer and let them repair it. It can get rather tricky trying to put those back together. I speak from experience and I work at a Miele dealer and I leave them for the other repair tech.
Jul 04, 2015 | Miele S548 Bagged Canister Vacuum
Why doe this hoover switch off after i start cleaning for about two minutes
You have to check the power switch button because it is mostly used part in the vacuum. A loose connection will occur and the power will shut off if that happened. Also clean the motor, if it is full of dirt you'll be sure motor will easily overheated caused it to premature shut down.
Good luck.
Jul 15, 2011 | Miele Cat & Dog 326i Bagged Canister...
Miele, Flamenco II. 2 probs. 1. the head brush is not turning when I put it on the floor. If I pick it up to look inside...the brush is spinning fast..I put it down on the floor...the head does not...
sounds like the belt is not on correctly on the beater brush or the belt is worned out now for the suction check filters or bags that need to be empty or clean
Feb 16, 2011 | Miele Vacuums
Opened the cannister to remove the bag. The tube
Steve,
This may be, and I stress MAYBE an issue with lining up the snap on the collar at the end of the hose (black tube). Please look carefully, using a flashlight or other bright light if necessary, to see if there is any indication on the collar for lining it up to 'snap' together. Unless the locking mechanism is broken off this should solve the problem.
Dec 04, 2009 | Miele Cat & Dog 326i Bagged Canister...
My vacuum over heated, the warning light has come on a the filters changed but it still refuses to reset and turn back on, any suggestions?
Could be fuse line! Estimated cost of repair $39-59.00 with 1yr warranty
Shipped USPS is very cheap and with our service it still beats many!!!!
Nov 23, 2009 | Miele Cat & Dog 326i Bagged Canister...
Miele cannister power up problem
8 identical screws holding the cover on. The control panel at the back has a screw and 2 push in clips. It lifts off and unclips the power.
May 21, 2008 | Miele Cat & Dog 326i Bagged Canister...
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
