Question about Vizio Televison & Video
Want to use my vizio E241-A1 TO SHOW PHOTO I HAVE ON FLASH DRIVE- BUT IT WILL SHOW SOME PHOTO BUT NOT ALL --I GET A MESSAGE THAT SAYS -FILE NOT SUPPORTED- SHOWS UP -WHA'S THE PROBLEM
WON'T SHOW ALL MY PICTURES FROM THE FLASH DRIVE-- I KEEP GETTING MESSAGES THAT SAYS--FILE NOT SUPPORTED-- BUT ALL PICTURES ARE FROM THE SAME FLASH DRIVE
  • 8 Answers
SOURCE: 'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Posted on May 01, 2009
SOURCE: can't get flash to work, get error message flashing on screen
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Posted on Jul 27, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
SOURCE: Can't send pictures or mulitimedia files to any phone from Mototola L6
have nokia 6600 i cant send pictures via blue tooth...becouse sendin option is not display..i wan to knw about it..plz help me
Posted on Dec 07, 2009
SOURCE: Hi, My Vizio Gallevia 42 is showing a
My Vizio Gallevia 42 is showing a "no signal" message and then shutting itself off. Do you know what that means
Posted on Dec 24, 2009
How to fix? power on white light on no backlight no video cannot turn power off
most likely the main board, BUT not a guarantee. one of the ways Vizio keeps the cost low is by high integration and low parts count. with minimal daughter boards.
Apr 03, 2016 | Televison & Video
Universal code for vizio E241 i-A1 tv
2038,2047,2037. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
May 17, 2015 | Vizio Televison & Video
I have a Vizio model# E241-A1-A1 with no power.Replaced the power supply board, still no power. Can you help.
Hi Clifford,
Why did you replace the power board? No power in your tv may result due to some other reasons also. Diagnosing a fault in any TV needs a certain amount of knowledge and expertise. Without that you may succeed at times, not always. By the way, do you get red led on plug in?
May 05, 2015 | Vizio Televison & Video
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio XRT010 Remote for E320-A0 E241-A1...
Why does the picture on my Vizio tv (model E241-A1) gets bright then darkens?
Check to see if you have a daylight savings option in your TV's settings. It will adjust the screen automatically according to the light changes in your home if it is enabled.
Sep 14, 2014 | Vizio Televison & Video
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Hello, I have an 8GB PNY flash drive. Recently, I plugged it into my laptop and it does not show a single file on the drive. It shows the drive is full when I go to properties, but there is nothing on...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Feb 11, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
