Question about RCA D52W19 52" Rear Projection Television
RCA d52W19Byx1 Set came in completely dead. Replaced swp/power supply PCB. When first plugged in, power light will come on briefly. There is a 57V supply on a resistor directly beside the largest ribbon cable on the swp board side. With the ribbon cables connected, it reads 1.5mv on one side and 23V on the other. with the cables disconnected, it reads 57V on both sides. (have tried new cables) Could the small signal board be bad??????Any help would be appreciated. Thanks, Chuck
  • Anonymous Mar 05, 2008
    have the same tv no power,no lights nothing suspect part ip020 defective
    Problem Solver:
  • 13 Answers
Check to standby voltages, the three of the five and a 7.5 voltage going to the SSB main PCB if these voltages are there most likely have no horizontal drive.  You'll need to replaced the SSB part # 264120. I recommend that you have an authorized RCA servicer replaced the board, convergence data needs to be uploaded to a computer via a chipper checker.  Because a full convergence is quite difficult.
                                      Packman
Posted on Oct 29, 2007
I have a 52 RCA flat screen that the sound works but the pic doesn't. I can hear a clicking sound and then the power button light starts flashing
This RCA projection tv model have known to have many parts of capacitors components are dying and dead on the tv power supply board.That the board section where the tv power a/c cord plug into it.U have all the tools and can do bsaic soldering work too?Yes,try website like Tvrepairworld.com to buy the capacitors compponents set they put together and replaced all these capacitors parts on the tv power supply board section,will solved this problems.
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
Wont turn on
If there are no lights at all coming on, its ,more than likely the power supply pcb that needs to be replaced. I hope this helps
Sep 16, 2010 | Samsung LN32A330 32 in. LCD TV
Rca d52w19byx1 when i turn on, the light blink 3 times then dead
Capacitors cp120 cp114 cp150 look to see if they are swollen vented or puffed up on top.220uf 35v and 1000uf 16v use 25v.
Jun 01, 2010 | Televison & Video
I was wondering if I could get some help with a RCA F22715 32" TV, please. Was working fine, then got up one morning and tried to power on. No green light on top of set, remote wouldn't power it up. Power...
I would check the (hot) or horzional out put transistor. Its possibly shorted. Also check the power supply for any other secondary fuses. They may look like a resistor, but they could be identifed on the pcb. Look at all the capacitors in the power supply to see if any are bulging on the top or leaking at the bottom. Alway replace any compoenent with the same value. Hope this is helpful.
Nov 26, 2009 | RCA F32715 32" TV
The power button light blinks a few times but no power afterwards. RCA D52W25 is dead. I lightly shook the TV last night and it worked until this morning.
These units are famous for loose solder connections at the high voltage transformer and for bad capacitors in the power supply. Have a repair shop check it out for you. You have to remove the Deflection PCB to do these repairs. Thanks
Oct 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replaced the fuse in RCA R52wm24 and resoldered the flypack now the tv power light turns on blinks three times then turns back off. We had no issues with the tv before today. Any help is greatly...
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Oct 06, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
I have an emerson tv and it will not power on at all. The little light wont even come on.
Solution 1 was just step 1. If the outlet gets power and the fuse or circuit breaker is ok, then U have a bad tv. That seems to be the most common problems with lcd's when they go bad. They either give the blinking light and not coming on, or they go completely dead. Most common causes are a bad power supply or a bad board/PCB/Circuit board.
Apr 20, 2009 | Emerson EWL3706 37 in. LCD Television
RCA D52W19 52" Rear Projection Television Logo
337 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
