Question about Optics
2002 pathfinder wants to take off by itself and seems like it has something to do with cruise control.
SOURCE: 2002 Pontiac Grand Am Cruise Control
Try blowing trash out of the unit attached to the steering wheel.Sometimes,this'll eliminate the issue.If not,U may have to replace the unit.
Posted on Jul 24, 2008
  • 99 Answers
SOURCE: 1988 Nissan Pathfinder Cruise Control and Side mirrors
In the fuse box driver side. If you pull out the panel covering the fuse box there is a decal inside behind the cover that should tell you what it fuse section does. There are ACC 1 and another section ACC 2. Or you can simply just pull out the fuses one at a time and see which one is burnt. If it burns out again, then you have a short. The fuses are clearly marked in the box to what they belong to. Example: Cig Lt (Cigarette Lighter) HD Lmp (Head Lamps) Etc.
You also need to check near the positive terminal of the battery the fuse links that are there. Perhaps the one that feeds the accessories portion is burnt. How do you know is burnt. Two orange ones, three green ones and one is black or grey. If is burnt, it will feel rubbery like or clearly show the burn by a black coloring or greyish coloring if its the black one. You can check them with a volt ohm meter for continuity from one end to the other. If you don't have a continuity reading the link is bad and needs to be replaced.n I eliminated all my fuse links and replaced them with fuse holder adapters where I can just change the fuse 10 amps or 15 amps depending on the circuit, but those only go if someone is messing with the circuit and accidentally shorts the circuit. Good Luck!
Posted on Oct 29, 2008
Murphybanton
  • 2004 Answers
SOURCE: BROKEN CRUISE CONTROL 2002 BUICK RENDEZVOUS
A fuse is broken. Let an expert check to determine this.
Posted on Apr 10, 2009
  • 70 Answers
SOURCE: cruise control ford escape 2002. ford escape
If the cruise lamp comes on and the cruise does not set i would advise inspecting the cruise cable and make certain it is not broken, if ok the the servo has likely failed.
Posted on May 29, 2010
Mustgo
  • 2359 Answers
SOURCE: the cruise control disengages by
Here a picture of the 2002 Dodge Intrepid cruise control unit. mustgo_28.jpg
I recommend you to clean it with PB Blaster spray /clean before starting trouble-shooting. mustgo_3.gif
Use small amount to wipe the cable and connector of the unit.
Make use the long cable is route correctly.
SEE the cable pathway for plastic ties and clips.
The last owner or service test may work on this area and forget to re-fasten the cable,
Look for damage on the cable and connector.
Check the accelerator linkage and cable for free play.
Check for free play around the throttle position sensor (TPS).
Check for missing ties / clips on the cruise control system.
DO NOT rule out a worn actuator (round unit) on cruise control system.
Please keep me posted on the fix via email.
Posted on Jan 25, 2011
Where is the Body Control Module located on this vehicle?
What is the name of the vehicle?????
What a Faulty PCM and BCM Can Cause... - YouTube
? 3:50
www.youtube.com/watch?v=2rudYtZUahQ
Feb 24, 2011 - Uploaded by DanielJaegerFilms
I have a 2002 impala Ls and my cruise control seems to turn on by itself ... In automotive electronics, BCM ..
Nov 05, 2015 | Cars & Trucks
Whats it mean when driving on the highway in your
It means you probably will need a tow off the highway to a garage.
Please tell us the answer to this question as you found out because I am just intrigued by this myself!
Sep 18, 2014 | 1995 Nissan Pathfinder
2010 Nissan Pathfinder Cruise Control issues
First I'll assume you haven't read the owners Manuel, Cruise control is not perfect on any vehicle. if coming to a hill put foot on gas to help rpm, going down hill put foot on brake to keep same speed, cruise control operates off of engine vacuum. Speed sensors can be affected by putting on smaller or bigger tires than what is on drivers door.
May 24, 2017 | 2010 Nissan Pathfinder
The cruise control light comes on but it does not engage. It's a 1995 pathfinder.
If your light comes on but the cruise control does not engage you may have a vacuum leak some where. When you set your cruise control your vehicle uses vacuum to maintain speed and if you have a vacuum leak this can not happen. Try checking all of your vacuum lines. I hope this helps.
Aug 26, 2011 | 1995 Nissan Pathfinder
Cruise control
this is happening because once you shut it off you are sending an electronic signal to transmission and it resets itself once car starts back up as if something inside the ecm has been reprogrammed and erased alll over again. the ecm is your brain which controls your car. get a diagnostic scan ran on it ok?
Jul 26, 2009 | 2004 Jaguar S Type
Apr 10, 2009 | 2002 Buick Rendezvous
I have a problem with the "cruise control" from my Nissan
Hi, replace the resume/accel switch. I've seen alot of failures on this. If it still doesn't work, the cruise control module is the only thing that can possibly cause this problem. It's located in the left rear quarter panel behind the spare tire and plastic trim.
Mar 15, 2009 | 1992 Nissan Pathfinder
Optics Logo
27 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
