Question about Karcher Garden
I require a user manual for 530M power washer
Please can you advise me where I can obtain a user and maintenance manual for the above Karcher power washer. Thank you
4 Suggested Answers
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
hawk127311
  • 350 Answers
SOURCE: have you got a manual for karcher k2900m pressure
Click on the link below. I hope this helps and good luck!
http://www.pressurewashersdirect.com/manuals/G2500OH_2.pdf
Posted on Nov 06, 2009
  • 15 Answers
SOURCE: User's Manual
Here's the User Manual..for Model K 5.93M
http://www.karcher-canada.com/support/downloads/pdfs/usermanuals/5962-1700.pdf
Posted on Jul 14, 2010
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Can you suggest an alternative soft flexible hose for a Karcher power pressure washer 100bar
You need to ensure the Hose can handle the PRESSURE your machine is putting out. The Flexibility is a direct correlation to the requirement of the hose's ability to handle the pressure. Your 100 Bar is equal to 1460 psi. Depending on where you live, there are places that have Hose and Couplers and can make a Hose to your Specifications with the above information.
Mar 21, 2015 | Karcher Garden
I need a service handbook for a Karcher 3.96M pressure washer. also known as Karcher 1.636-105
First of all, thank you very much Kelly for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://dl.owneriq.net/b/b3c635f2-6141-4694-8ef1-b74cdc61b258.pdf
And here is a link to the SPARE PARTS LIST / EXPLODED VIEW SERVICE DIAGRAMS for that model:
http://www.pressure-power-washer.com/pdf/karcher/5970-5590.pdf
To view the Owner's Manual with Operating Instructions or the SERVICE DIAGRAMS just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Apr 06, 2012 | Karcher Garden
Pressure hose not working on Karcher pressure washer
A common problem with these is a pressure valve inside the unit that controls the power to the pump. If the unit has not been used for some time the valve can stick.
Does the motor run when you press the trigger?
Please respond and I will advise further. (add a comment)
Apr 06, 2010 | Karcher Garden
LG RZ 15LA70 User Manual
I contacted the shop I purchased the television from.
I sent an e-mail to LG requesting how to obtain a copy of the manual for RZ/15LA70 LG T.V. with no resonse.
My E-mail address is katecullinan2002@yahoo.co.uk
Jan 21, 2008 | Televison & Video
Breville fan assisted breadmaker manual required
Hello, Try this website link. It connects directly to Breville's website request form for user manuals in Australia. Good Luck! Dr. Know
Dec 21, 2007 | Kitchen Appliances - Others
Garden Logo
16 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
