Question about Acer 7741z-4433-Aspire 7741z-4433 Pdc 2.13ghz 4gb 320gb Dvdrw 17.3
When turning on laptop, message tfght is compressed press ctrl-Alt-del
5 Suggested Answers
  • 17 Answers
SOURCE: bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Posted on Feb 27, 2009
  • 34 Answers
SOURCE: won't start
sounds like maybe a hard disk problem but there is a couple of things to try go in the bios and see if it recnioze it and if it dont have u recently removed the drive sometime a loose connection will cause this.but if u have not removed the drive u should still check it to make sure it has a good connection.
Posted on Mar 24, 2009
fraywing
  • 37 Answers
SOURCE: cannot restart laptop
"Boot with the Vista DVD, when it enters Setup hit your SHIFT-F10 keys Setup will run "cmd", and drops you to a command prompt that is running with SYSTEM privileges.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
hope this helps! :)
cite: http://www.cybertechhelp.com/forums/showthread.php?t=151686
Posted on May 30, 2009
  • 3 Answers
SOURCE: laptop help
sounds like something got hosed up......use the recovery partition and reload windows....easiest thing to do....Good luck...
Posted on Jan 15, 2010
If TFGHT is compressed, can i reformat my laptop without cd? or pressing long 0. give me an answer. please! :
Saving space by compressing the drive is not a good thing.
What follows applies to both 32- and 64-bit Windows Vista and Windows 7.
The tip off that the Windows drive has been compressed is a message which looks like the following. 'Some file' in the message can be anything. It might be BootMgr, TFGHT, QXHDK, DFJEU, VUFEI, DGKAR,..
'Some file' is compressed. Press CTRL+ALT+DEL to restart.
Windows will not start.
1. The first step to fixing this is to begin the process which leads to the Windows Recovery Environment (aka WinRE). In both Vista and W7, one can use an installation DVD if available. In many OEM environments (including Toshiba's), one can use the entry Repair Your Computer on the F8 Advanced Boot Options menu. In Windows 7, one can use a System Repair disc.
2. On the way to WinRE, you will encounter a screen that looks like this.
3. Click the Load Drivers button and you will find yourself looking at folders on your computer..
4. Find Computer on the left side (the navigation pane) and left-click it.
5. On the right side, right-click the drive with Windows (the C drive) and click Properties in the pop-up.
6. At the bottom of the Properties box, clear the check box that says Compress this drive to save disk space.
7. Another window will pop up asking you to confirm the change. The windows will get messy at this point. You'll need to move them around the screen to see things. Don't panic.
8. On the new window, set Apply changes to drive C:\, subfolders and files, and then click OK.
9. Now you'll need to wait for a few minutes while the decompression takes place. You won't see a progress indicator.
10. After your hard disk stops showing activity, cancel the remaining boxes and restart the computer. It should boot normally.
Nov 16, 2015 | Toshiba Computers & Internet
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Its saying boot mgr is compressed press ctrl+alt+del to restart but when i do that it just goes back to the same thing boot mgr is compressed press ctrl+alt+del to restart
You need to format your Laptop or you can try replacing the Boot files from another Laptop.
You can try repairing your OS by booting the original disc.
Dec 08, 2011 | Toshiba Computers & Internet
TFGHT FILE IS COMPRESSED PRESS ALT+CTRL+DEL. FROM DELL INSPIRON MINI NOTE BOOK. ANY SOLUTION?
reinstall windows with the resore option when powering up hold the 0 key down until you hear a long beep then select the restore my computer option
Jan 28, 2011 | Dell Inspiron Mini 10 Notebook
When i start my computer iget the message "tfght compressed press ctrl alt and delete
i think... you better change your hard drive and install a new os..... **** **** my loptop also .......why they will give a compress selection f there is a side effect.......****,,,, you all who make that........
Dec 19, 2010 | HP Pavilion dv9260nr Notebook
YJQBX is compressed message
reset your computer and turn it back on good luck... ;)
Jun 06, 2010 | ASUS Eee PC 1000H Netbook
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Acer 7741z-4433-Aspire 7741z-4433 Pdc 2.13ghz 4gb 320gb Dvdrw 17.3 Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
