Question about Oakley Transistor Eyeglasses Frame - Polished Black
How to remove the lenses of the oakley transistor frame for cleaning the dirt stuck in the edge?
Which sunglasses do you suggest I wear for when I play softball in the middle of the day?
I have Oakley glasses with iridium lenses that I absolutely love. They completely protect my eyes and they don't hurt after a long day in the sun. Oakley make a lot of different frames for iridium glasses but really anything iridium is fine.
Jan 14, 2013 | Baseball & Softball
Cant find holbrooke oakley lenses replacement... if there any way replacement lenses for tham&
Typically Oakley has replacement lenses for their glasses but because the Holbrooke is so new it is probably going to be awhile before they have parts available. The guys at www.sunglassreplacementlenses.com could probably custom make you a set of after market lenses for about half of what Oakley will want for their lenses. You may want to email them if your lenses are thrashed.
Thanks
Jun 03, 2011 | Oakley Holbrook Sunglasses
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
How to replace the lenses for oakley spike
I did the following... step by step, if you have any questions, please ask. - I placed the sunglasses perpendicular to me. One if the lenses will be close to you, while the other should be farther away.
-I grabbed the farthest lens from your body with both hands. Placing your left had on the left side and your right and on the right side. One had is on the bottom of the lens, while the other is on the top of the lens. It does not matter which hand is on the bottom or top.
-I grabbed the top and bottom of the frame, pulling away from the lens. At the same time I pushed with my fingers (that should be on the inside of the lenses) and pressed the lens out (on the lens closest to the nose pieces). You will hear a very faint "pop" when the lens clears the frame.
-Then slide the lens out by grabbing the part that is out of the frame that is close to the nose piece
-To put the new ones in, position the sunglasses the same way and put the replacement lens in the sunglasses, starting with the edge near the ear pieces.
-Pull the top and bottom of the frame out and push the replacement lens into place.
If you have any questions, please ask. If I can clarify anywhere, let me know.
Good luck.
And once you do this,could you please leave me feedback and vote on my answer?
Thank you very much,
Lori
Mar 17, 2011 | Oakley Spike Sunglasses
Can't find replacement lenses for Oakley Holbrook polished black/gray polorized
You can order replacement lenses from Oakley on the link below.
http://www.oakley.com/search?Ntt=Replacement+Lenses
If you do not see the lenses on the link contact oakley at this link below to order them.
http://www.oakley.com/customer-care/customer-care-info
Mar 13, 2011 | Oakley Holbrook Sunglasses
Can you put prescription lenses into sunglasses frames? I have to get my eyes checked in about two weeks and I've gotten the use out of my current pair of glasses so I'm pushing to get new glasses. My...
Yes it is possible.. Oakley makes RX lenses specifically for some of the frames. the previous poster makes some invalid points in terms of what you are talking about. Oakley makes many more frames than just "sporty" frames that fit tight to your head. Oakley glasses are held onto your head by the shape AND by the hydrophilic rubber pieces (called Unobatnium) in glasses that are less wrapped. You mentioned that these looked like Rx Frames / regular glasses frames. Please note, Oakley makes RX frames, as well.
If you go to Oakley's website and look under Rx Sunglasses, you'll see which can be made with prescription lenses, AND ones that you can have an Optometrist cut regular lenses to fit.
However, please note, many Opticians, have lab do their cutting work and some labs will NOT cut for an Oakley frame. If your eye doc allows you to take him a frame, then he should be able to have it cut. It depends on the lab. It may be easier to find a Optometrist with his won lab on site. Those are places that will custom cut.
Of course, if you, as the previous poster stated, do go with a very sunsglasses / sport model, you'll need to stick with the Oakley specific sport sunglasses lens as the lense curvature may be hard to match.
Nov 07, 2010 | Clothing Accessories
How do i remove the front screen to clean the mirror on the inside
usually you need to remove the speaker grille then you will notice a few screws in the lower screen frame remove thos screws then grab the screen frame and slide up wards to disengage the clips that hold the screen assembly on.
May 16, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Oakley Transistor Eyeglasses Frame - Polished Black Logo
Top Oakley Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Oakley Health and Beauty Expert? Answer questions, earn points and help others
