Question about Gaggenau VR 322-612 Indoor Grill
Burner won't heat up - Gaggenau VR 322-612 Indoor Grill
Oven won heat unless burner is on
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
I change the thermocople but now the burner don't lit
Hi there!
Check if the thermocouple is properly heated by the pilot flame.
Check also if the hi limit has continuity across the terminals.
Regards.
Apr 23, 2012 | Star 30lb Gas Counter Top Deep Fryer 630fd...
Bottom burner won't heat up
shut the breaker off to the unit. if the bottom burner is exposed remove the screws at the back of the burner and ease the burner out. there will be a wire connected to each side of the burner. remove both of the wires and test the connections of the buner for resistance with an ohm meter if open you need a new burner if not it could be a control. this is assuming your range is electric not gas
Mar 27, 2012 | Ovens
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
Are lava rocks used with charbroil 463731703? Can they be used with this bbq?
Since your grill uses a V - bar flame tamer over the burner, I wouldn't recommend using Lava Rocks. As there is no grate to set them on above the burner. Putting them directly over the V-bar flame tamer, won't allow the burner to heat evenly and you'll have hot and cold spots throughout the cooking surface.
Hope this answers you question.
Apr 23, 2011 | Char-Broil QuickSet 463731703 (LP) Grill
Gaggenau VR 322-612 Indoor Grill Logo
29 people viewed this question
Top Gaggenau Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Gaggenau Kitchen Appliances - Other Expert? Answer questions, earn points and help others
