Question about Samsung / RF197ACRS
Not Cooling Fridge and Freezer not cooling - it was working but all of sudden stopped cooling in both sections
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
  • 117 Answers
SOURCE: Samsung RSH1DBRS twin cooling unit - following a
this may help ">
Posted on Sep 15, 2010
heatman101
  • 43501 Answers
SOURCE: Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
The freezer is not freezing. Is cold only.
The problem which you mentioned is related to faulty/ weak compressor.--------- I will explain with more detail.------
Jun 28, 2011 | Refrigerators
Frig stopped working but freezer is good? Help... I am handy.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
G.E. Bottom freezer evap drain keeps freezing up and ice build up stops fan so no cooling in fridge compartment. How can this be solved?
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 22, 2011 | Refrigerators
My samsung fridge section stops cooling but freezer is working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 25, 2010 | Samsung Refrigerators
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
heatman101
Sep 16, 2010 | Amana Refrigerators
Samsung / RF197ACRS Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
