Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung RF258 chimes are playing constanly. Why?
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: https://www.heath-zenith.com/support/owners-manuals . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is https://www.heath-zenith.com/system/spree/documents/attachments/000/000/839/original/205371-02A.pdf?1436551434 .
Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime.
Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime.
I hope this helps.
Jun 02, 2017 | Heath Zenith Home Security
2009 silverado 2500hd wt Diesel chime in ceiling does not work for any notifications, seat belt, low fuel, turn signal on, door any clue where to start looking.
The chime system is a class 2 databus. The chime is actually created by the factory radio and plays thru the left front speaker. If the radio is non factory and the appropriate kit was not used ( which has a speaker for the chine) or the front left speaker is blown then you won't have a chime. If you do have a factory radio and the speaker plays the music fine then the problem lies in either the data circuit or the radio. If you have an aftermarket radio and the correct wiring kit was used then either there is a bad connection, blown chime speaker or defective kit.
Aug 09, 2016 | Chevrolet Silverado 2500HD Cars & Trucks
I had to replace the doorbell button, now the doorbell only buzzes instead of chimeing. I have tried three different buttons and they all give the same result. Whats wrong?
This has to be a setting of dip switches that got changed somehow on the chiming unit. Open that up and check the settings.
Feb 22, 2015 | Home Security
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 | Home
SAMSUNG TV DOES NOT MAKE SOUND WHEN TURNING ON
That is normally a chime that plays only on initial set up.
Nov 13, 2014 | Samsung Televison & Video
Samsung RFG298AARS is cylcing between crushed and cubed ice several times a minute and chimes each time it does that!
\it could be that the switch for the ice selection is stuck or just went bad and shorted out. You can check with appliancepros.com to get price of switch and trouble shoot the problem
Apr 07, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
No warning chime for 2006 Ascender
I don't think it is a fuse.
The warning chimes for this vehicle come through the radio and are play to the speakers and if I remember correctly the chimes play to the left front speaker.
I would check for a faulty speaker or wiring to the speaker.
Sep 09, 2009 | 2006 Isuzu Ascender
Turning off the on/of chime for a samsumg series 5
In SETUP you will see.
Melody → Off / Low / Medium / High
# NOTE - If this info was helpful to anyone please click on yes!
Jun 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
23 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
