Question about Morphy Richards 43072 Cordless Electric Kettle
The switch on My Electric Kettle has broken
The actual switch is vey loose.It now does not operate
Kettle switch does not go up
If the switch is broken, you might find a repairer to fix it. But dont try any other way because of danger of shock. The kettle are very cheap these days , buy a new one.
Dec 04, 2013 | Hamilton Beach Kitchen Appliances - Others
On/off switch is BROKEN,HOW CAN I TURN THE KETTLE
Hanif, buy a new one because it will be difficult to find replacement and may even be costly. Kettles are cheap.
Oct 23, 2013 | Hamilton Beach 40870 Electric Kettle
Switch became totally loose and cannot be turned ON
you havent specified where the switch becomes loose and inoperable .......it is in the plug point or the base of the unit
if it is on the mains then change the point
it it is on the base of the unit ...
then give some padding to the base where the plug is connected then
it will start working////////
i hope this suggestion will solve your problem
Jan 08, 2011 | Braun WK200 Electronic Water Kettle...
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Morphy Richards 43072 Cordless Electric Kettle Logo
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
