Question about Maytag Centennial Top Load Washer
Looking for replacement part for Maytag washer
Looking for timer replacement part Invensys #W10243947
2 Suggested Answers
Cyril J
  • 45 Answers
SOURCE: timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
Posted on May 16, 2008
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Trying to replace timer on Kenmore 700 washing machine (model 110.28727200). The existing timer is an Invensys model W10129602. Where can I find replacement or substitute parts?
Here is the timer to order. To remove the knob on the old timer, from the back of the timer there is the knob pin that you push in and it will release the the knob.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Kenmore Washing Machines
Why does my maytag centennial agitate while it fills
The symptoms you are describing are most likely caused by a bad load sensing switch. The relay in the switch sticks and allows the washer agitate before it fills.
A simple check is to access the load sense switch and unplug the wires to it. Then check the operation. I have provided you with the instructions for accessing the load sense switch in the images below. I am also including the checks that can be made if you have a volt/ohm meter. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
Once the console is open the load sense switch is the switch that has the clear plastic hose connected to it. Remove the connector that has the violet, white and the blue with orange stripe from the switch. Then carefully plug the washer back in and start a wash cycle. If the washer does not do anything, you need to replace the load sense switch (part number W10177795). If the washer still agitates, the problem is most likely a failed timer (part number W10243947).
Image 1
Image 2
Nov 01, 2012 | Washing Machines
I have a MVWC7ESWW0. Starts agitating before water starts. Has about 2 inches of water in drum after spin cycle. Is this the auto-load sensor and if so what is the part number. Cannot find that sensor...
Could be the agitator delay circuit board, (Circuit Board, Agitation Delay part #W10104800), or maybe (W10243947 Timer). This is based on the parts manual.
Jul 24, 2011 | Maytag MVWC7ESWW Washer
Hi i'm looking for user instructions for an old style switchmaster 950 heating and water timer system. Thanks
Try contacting them here:
Invensys Climate Controls Europe
Telephone: +44 (0) 845 130 5522
Facsimile: +44 (0) 845 130 0622
Technical Helpline: +44 (0) 845 130 7722
Website: www.climate-eu.invensys.com
Email: customerservices@invensys.com
Just a note... I did not find a SM 950 but did manage to locate a SM 980
The website above links straight to This link: http://www.draytoncontrols.co.uk/content.aspx?id=2649
Under documentation they have programming instructions for the SM1 and SM2 that mention the SM980 under SM1 mechanical time switch here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
This may not be what your looking for. If not just don't rate the post please.
Kelly
Sep 27, 2010 | Heating & Cooling
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
Oct 03, 2008 | GE WCCB1030 Top Load Washer
Maytag washer will not agitate
ckd wiring connections motor and timer? if they look ok suspect timer ..motor contacts in timer may be shot
May 01, 2008 | Washing Machines
Maytag Centennial Top Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
