Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Limited edition dishwasher kenmore model 665.15899
3 Suggested Answers
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Posted on Jul 18, 2008
heatman101
  • 43501 Answers
SOURCE: i require the " clips
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Apr 20, 2011
Where can I find a bobbin case for Limited Edition #38519157100
I bleive the limited addition is a singer model. Any place that has singer parts shouldl be able to match it up.
www.singerco.com
Jun 25, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore Limited Edition 665 15899 draining incorrectly through overflow at top of sink. Is something plugged? How to fix?
Usually this type of setup (overflow) has a plugged or restricted hose going from it to the drain (or disposer).
If disposer, it is very common to have this port plug up over time.
Jun 18, 2011 | Kenmore 15899 Built-in Dishwasher
I require the " clips
heatman101
Apr 20, 2011 | Kenmore Dishwashers
Model 655-17014401 clean light (green) flashes but dishwasher won't start
This means you have an open heat circuit. It could be either a bad heating element, a bad hi limit thermostat, or a bad control board. The heater and hi limit therm can be tested for continuity with an ohm meter. Most of these units the heater will come with the control board in a kit. Hope this helps.
_MJ_
Dec 15, 2010 | Kenmore Dishwashers
I have a model 665.15831791 When it fills with water it does not go into a cycle, it automatically discharges the water
It could be two things causing such problem: no power to the wash pump motor or the motor itself is bad. Remove the wire plug from the motor and check for the 120V when the timer is on wash cycle. If there is no power then check the wires and the plug at the timer. If this is not an issue replace the timer.
If there is a proper power to the motor then the problem with your dishwasher is a bad wash pump motor. If your dishwasher is less then 5 years old then it could be under limited manufacturer warranty. Call kenmore with the model and the serial numbers and they will tell you. If the dishwasher is more then 5 years old I do not recommend you to repair it yourself. I've seen many times when it's not possible to install the pump back after repair because the plastic tub got warped.
here is the link to the schematic diagrams for your dishwasher ... you can also order for timer and other parts if need be from the same link as well
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-665.15831791/0582/0130000?pathTaken=
Sep 03, 2010 | Kenmore Dishwashers
Mar 30, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Have the Kenmore Limited Edition dishwasher, model # 665.15892100. When dishwasher is running, you can hear the soap container flip open. However, @ end of washer's completion, and main door is opened, the...
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Feb 02, 2008 | Dishwashers
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
