Question about Epic A30T Treadmill
My Epic A30t won't boot. It has a bar that moves across the screen like its loading. Can I reset it?
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: How to connect Epic A30T to Ifit
Dear Sir: Will be a Great idea that you connect with the next LINK and contact them.
http://support.ifit.com/home
or You can download FREE your instr. manual and follow the steps very easy. go to www. fitness.manualsonline.com
God bless you
Posted on Dec 07, 2012
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
SPEED OF TREADMILL ACCELERATES
please RUN the software calibration go under the HOOD motor and see the instruction, for easy diagnostic and fix it.
God bless you
Jul 10, 2013 | Epic A30T Treadmill
My treadmill will not connect to wifi.
go to https://www.ifit.com/install
install that update and try again, this will be fix it.you will need adobe go
http://get.adobe.com/air
God bless you
Jan 14, 2013 | Epic A30T Treadmill
God bless you
Dec 07, 2012 | Epic Exercise & Fitness
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
How do you do a master reset on palm centro cell phone?
Hard reset - remove battery, reinstall battery and hold down power button continuously as the "palm" screen loads and the black bar moves across the screen, release. The phone will then select a language and prompt for a reformat.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
Startup screen freezes
using the system restore disk, boot the laptop and choose repair, run chkdisk /r this repairs the system files, if this does not fix the problem, using the same system disk do a restore.
BPCS
Dec 06, 2007 | Dell Inspiron 8500 Notebook
Epic A30T Treadmill Logo
140 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
